跳转到主内容
Sony Ericsson z300 Motherboard Replacement
你所需要的
  1. Sony Ericsson z300 Motherboard Replacement, Back Phone Cover: 步骤 1 中的图像 1,1
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Sony Ericsson z300 Motherboard Replacement, Battery: 步骤 2 中的图像 1,1
    • Using a fingernail lift the battery out of the phone.
  3. Sony Ericsson z300 Motherboard Replacement, Sim Card: 步骤 3 中的图像 1,1
    • Slide the sim card out with your thumb.
  4. Sony Ericsson z300 Motherboard Replacement, Back Dark Grey Case: 步骤 4 中的图像 1,1
    • To remove the back case first remove the four screws shown with a T5 Torx screwdriver
  5. Sony Ericsson z300 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
  6. Sony Ericsson z300 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Lift up towards the bottom and slide the case off.
  7. Sony Ericsson z300 Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,1
    • Use a plastic opening tool to lift up the brass colored panel.
  8. Sony Ericsson z300 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Flip up the yellow tab using a plastic opening tool to disconnect the motherboard from the phone body.
  9. Sony Ericsson z300 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Work the plastic opening tool around the edges of the motherboard to release it from the clips.
结论
另外一个人完成了本指南。
Alex Serventi
于10/07/10注册
65 声望
创作了13篇指南
团队
Cal Poly, Team 5-15, Maness Fall 2010 Cal Poly, Team 5-15, Maness Fall 2010 的会员
CPSU-MANESS-F10S5G15
4 名成员
创作了26篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 2,142
