当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
To remove the back cover, use your thumb to press down on the center of case and slide it off.
Using a fingernail lift the battery out of the phone.
Slide the sim card out with your thumb.
To remove the back case first remove the four screws shown with a T5 Torx screwdriver
Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
Lift up towards the bottom and slide the case off.
Use a plastic opening tool to lift up the brass colored panel.
Flip up the yellow tab using a plastic opening tool to disconnect the motherboard from the phone body.
Work the plastic opening tool around the edges of the motherboard to release it from the clips.
Using a plastic opening tool lift up the keypad to remove it.
Use a plastic opening tool to lift the microphone out of its circular slot.
取消:我没有完成这个指南。
与4其他贡献者
于10/07/10注册
65 声望
创作了13篇指南
徽章: 10
+ 7更多徽章
CPSU-MANESS-F10S5G15
4 名成员
创作了26篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,874
