跳转到主内容
Sony Ericsson xPeria Active Screen Replacement
你所需要的
  1. Sony Ericsson xPeria Active Screen Replacement, Remove the back cover.: 步骤 1 中的图像 1,3 Sony Ericsson xPeria Active Screen Replacement, Remove the back cover.: 步骤 1 中的图像 2,3 Sony Ericsson xPeria Active Screen Replacement, Remove the back cover.: 步骤 1 中的图像 3,3
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Sony Ericsson xPeria Active Screen Replacement, Remove inside plastic battery cover.: 步骤 2 中的图像 1,2 Sony Ericsson xPeria Active Screen Replacement, Remove inside plastic battery cover.: 步骤 2 中的图像 2,2
    • Remove the battery shield with the plastic opening device.
  3. Sony Ericsson xPeria Active Screen Replacement, Remove the battery: 步骤 3 中的图像 1,2 Sony Ericsson xPeria Active Screen Replacement, Remove the battery: 步骤 3 中的图像 2,2
    • Remove the battery.
  4. Sony Ericsson xPeria Active Screen Replacement, Unfastening The Motherboard Cover: 步骤 4 中的图像 1,1
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  5. Sony Ericsson xPeria Active Screen Replacement, Removing The Motherboard Cover: 步骤 5 中的图像 1,2 Sony Ericsson xPeria Active Screen Replacement, Removing The Motherboard Cover: 步骤 5 中的图像 2,2
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
  6. Sony Ericsson xPeria Active Screen Replacement, Screen: 步骤 6 中的图像 1,2 Sony Ericsson xPeria Active Screen Replacement, Screen: 步骤 6 中的图像 2,2
    • Unplug the power cable by carefully prying it away from the motherboard.
  7. Sony Ericsson xPeria Active Screen Replacement: 步骤 7 中的图像 1,2 Sony Ericsson xPeria Active Screen Replacement: 步骤 7 中的图像 2,2
    • Remove the power strip on the back side of the motherboard.
  8. Sony Ericsson xPeria Active Screen Replacement, Remove back screen shield: 步骤 8 中的图像 1,2 Sony Ericsson xPeria Active Screen Replacement, Remove back screen shield: 步骤 8 中的图像 2,2
    • Remove the shield.
  9. Sony Ericsson xPeria Active Screen Replacement, Remove the screen module: 步骤 9 中的图像 1,2 Sony Ericsson xPeria Active Screen Replacement, Remove the screen module: 步骤 9 中的图像 2,2
    • Push the screen through the front of the case, gently.
    • It may be a little tough, just work your way around the edges of the screen until it separates from the main case.
结论
5等其他人完成本指南。
Alex Tobin
于10/06/14注册
406 声望
创作了3篇指南
团队
USF Tampa, Team 14-5, Leahy Fall 2014 USF Tampa, Team 14-5, Leahy Fall 2014 的会员
USFT-LEAHY-F14S14G5
3 名成员
创作了5篇指南
一条评论
hi can you add explain
abdnour master2 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 20
总计 2,345
