跳转到主内容
Sony Ericsson xPeria Active Headphone Jack Replacement
你所需要的
  1. Sony Ericsson xPeria Active Headphone Jack Replacement, Remove the back cover.: 步骤 1 中的图像 1,3 Sony Ericsson xPeria Active Headphone Jack Replacement, Remove the back cover.: 步骤 1 中的图像 2,3 Sony Ericsson xPeria Active Headphone Jack Replacement, Remove the back cover.: 步骤 1 中的图像 3,3
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Sony Ericsson xPeria Active Headphone Jack Replacement, Remove inside plastic battery cover.: 步骤 2 中的图像 1,2 Sony Ericsson xPeria Active Headphone Jack Replacement, Remove inside plastic battery cover.: 步骤 2 中的图像 2,2
    • Remove the battery shield with the plastic opening device.
  3. Sony Ericsson xPeria Active Headphone Jack Replacement, Remove the battery: 步骤 3 中的图像 1,2 Sony Ericsson xPeria Active Headphone Jack Replacement, Remove the battery: 步骤 3 中的图像 2,2
    • Remove the battery.
  4. Sony Ericsson xPeria Active Headphone Jack Replacement, Unfastening The Motherboard Cover: 步骤 4 中的图像 1,1
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  5. Sony Ericsson xPeria Active Headphone Jack Replacement, Removing The Motherboard Cover: 步骤 5 中的图像 1,2 Sony Ericsson xPeria Active Headphone Jack Replacement, Removing The Motherboard Cover: 步骤 5 中的图像 2,2
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
结论
3等其他人完成本指南。
Daniel
于10/13/14注册
437 声望
创作了2篇指南
团队
USF Tampa, Team 14-5, Leahy Fall 2014 USF Tampa, Team 14-5, Leahy Fall 2014 的会员
USFT-LEAHY-F14S14G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 741
