跳转到主内容
Sony Ericsson xPeria Active Camera Replacement
你所需要的
  1. Sony Ericsson xPeria Active Camera Replacement, Remove the back cover.: 步骤 1 中的图像 1,3 Sony Ericsson xPeria Active Camera Replacement, Remove the back cover.: 步骤 1 中的图像 2,3 Sony Ericsson xPeria Active Camera Replacement, Remove the back cover.: 步骤 1 中的图像 3,3
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Sony Ericsson xPeria Active Camera Replacement, Remove inside plastic battery cover.: 步骤 2 中的图像 1,2 Sony Ericsson xPeria Active Camera Replacement, Remove inside plastic battery cover.: 步骤 2 中的图像 2,2
    • Remove the battery shield with the plastic opening device.
  3. Sony Ericsson xPeria Active Camera Replacement, Remove the battery: 步骤 3 中的图像 1,2 Sony Ericsson xPeria Active Camera Replacement, Remove the battery: 步骤 3 中的图像 2,2
    • Remove the battery.
  4. Sony Ericsson xPeria Active Camera Replacement, Unfastening The Motherboard Cover: 步骤 4 中的图像 1,1
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  5. Sony Ericsson xPeria Active Camera Replacement, Removing The Motherboard Cover: 步骤 5 中的图像 1,2 Sony Ericsson xPeria Active Camera Replacement, Removing The Motherboard Cover: 步骤 5 中的图像 2,2
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
  6. Sony Ericsson xPeria Active Camera Replacement, Unplug the back motherboard plug.: 步骤 6 中的图像 1,2 Sony Ericsson xPeria Active Camera Replacement, Unplug the back motherboard plug.: 步骤 6 中的图像 2,2
    • Unplug the plug from the motherboard.
  7. Sony Ericsson xPeria Active Camera Replacement, Remove motherboard from device case.: 步骤 7 中的图像 1,1
    • Using the plastic opening tool, carefully pry up on the edges of the motherboard, opposite of the jacks.
  8. Sony Ericsson xPeria Active Camera Replacement, Remove the display ribbon cable: 步骤 8 中的图像 1,2 Sony Ericsson xPeria Active Camera Replacement, Remove the display ribbon cable: 步骤 8 中的图像 2,2
    • Carefully pry up on the tab holding down the display ribbon cable and remove the ribbon cable.
  9. Sony Ericsson xPeria Active Camera Replacement: 步骤 9 中的图像 1,2 Sony Ericsson xPeria Active Camera Replacement: 步骤 9 中的图像 2,2
    • Use the plastic opening tool to pry the ribbon cable away from the motherboard.
  10. Sony Ericsson xPeria Active Camera Replacement, Remove camera from device: 步骤 10 中的图像 1,2 Sony Ericsson xPeria Active Camera Replacement, Remove camera from device: 步骤 10 中的图像 2,2
    • Pull the camera out through the front of the motherboard.
结论
另外一个人完成了本指南。
Alex Tobin
于10/06/14注册
406 声望
创作了3篇指南
团队
USF Tampa, Team 14-5, Leahy Fall 2014 USF Tampa, Team 14-5, Leahy Fall 2014 的会员
USFT-LEAHY-F14S14G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 795
