跳转到主内容
Sony Ericsson s710a SIM Card Replacement
  1. Sony Ericsson s710a SIM Card Replacement, SIM Card: 步骤 1 中的图像 1,1
    • Slide the battery cover off by pushing it away from the camera side of the device.
    • This may require a good amount of force.
  2. Sony Ericsson s710a SIM Card Replacement: 步骤 2 中的图像 1,1
    • Next remove the battery
    • Lift it out of the phone using the tab on the battery (marked in the image)
  3. Sony Ericsson s710a SIM Card Replacement: 步骤 3 中的图像 1,1
    • The SIM card holder is now exposed (marked in image).
    • This will likely already have an existing SIM card in it if the phone has been previously used.
    • To open this, slide the holder upward (assuming the same orientation as in the image)
  4. Sony Ericsson s710a SIM Card Replacement: 步骤 4 中的图像 1,1
    • The holder will then hinge open.
    • You are now able to insert a new SIM card.
  5. Sony Ericsson s710a SIM Card Replacement: 步骤 5 中的图像 1,1
    • Insert the new SIM card in the orientation shown.
    • This is important, as the phone will not work if the metal contacts on the card are not properly aligned with the contacts on the phone.
  6. Sony Ericsson s710a SIM Card Replacement: 步骤 6 中的图像 1,1
    • Now hinge the SIM card holder down so that it lays flat in the phone.
    • Slide the plastic holder downwards to lock it in place.
    • Now the battery and cover can be put back in place.
结论
另外一个人完成了本指南。
Alexander
于10/29/11注册
75 声望
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,834
