跳转到主内容
Sony Ericsson s710a LCD Screen Replacement
你所需要的
  1. Sony Ericsson s710a LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the back cover by sliding it off.
  2. Sony Ericsson s710a LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Pull the battery out using your finger.
  3. Sony Ericsson s710a LCD Screen Replacement: 步骤 3 中的图像 1,1
    • The battery can now be replaced.
    • The battery is a 780 mAh rechargeable Lithium Ion battery.
  4. Sony Ericsson s710a LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 1,1
    • Remove the four 6 mm screws from beneath the battery using a Phillips #00 screwdriver.
  5. Sony Ericsson s710a LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the microphone cover using the iFixit opening tool.
  6. Sony Ericsson s710a LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the two 6 mm screws from the front of the phone beneath the microphone cover using a Phillips #00 screwdriver.
  7. Sony Ericsson s710a LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Remove the black plastic piece on the side.
    • This will allow for easier access while prying the motherboard.
  8. Sony Ericsson s710a LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Use the iFixit opening tool to loosen the motherboard from the phone.
  9. Sony Ericsson s710a LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Lift the motherboard out with your fingers.
    • Pull slowly. This will require some force.
  10. Sony Ericsson s710a LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Remove the two cable connectors using the iFixit opening tool.
    • Mark the orientation and port of each cable before detaching them. The connectors are symmetrical, so this is essential for reassembly.
  11. Sony Ericsson s710a LCD Screen Replacement: 步骤 11 中的图像 1,1
    • On the rotational assembly remove the following screws:
    • Four 3 mm screws
    • Two 2.3 mm screws
    • Lift the rotational assembly off of the phone to allow access to the other half of the device.
  12. Sony Ericsson s710a LCD Screen Replacement: 步骤 12 中的图像 1,1
    • Detach the cable connectors on the other end of the cables using a plastic opening tool.
    • Record the orientation and location of each connector for reassembly.
  13. Sony Ericsson s710a LCD Screen Replacement: 步骤 13 中的图像 1,1
    • Remove the plastic cover on the back of the phone using an iFixit opening tool.
    • Remove the four 6 mm screws using a Phillips #00 screwdriver.
  14. Sony Ericsson s710a LCD Screen Replacement: 步骤 14 中的图像 1,1
    • Pry the screen assembly from the main case using the iFixit opening tool.
  15. Sony Ericsson s710a LCD Screen Replacement: 步骤 15 中的图像 1,1
    • With the face plate and LCD screen exposed, replace the existing LCD screen with a new LCD screen.
    • Be sure to test and make sure the detachable connections are arranged correctly.
结论
Jamel Lugg
于10/29/11注册
1 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 1,593
