跳转到主内容
Sony Ericsson s710a Keypad Replacement
你所需要的
  1. Sony Ericsson s710a Keypad Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the back cover by sliding it off.
  2. Sony Ericsson s710a Keypad Replacement: 步骤 2 中的图像 1,1
    • Pull the battery out using your finger.
  3. Sony Ericsson s710a Keypad Replacement: 步骤 3 中的图像 1,1
    • The battery can now be replaced.
    • The battery is a 780 mAh rechargeable Lithium Ion battery.
  4. Sony Ericsson s710a Keypad Replacement, Keypad: 步骤 4 中的图像 1,1
    • Remove the four screws using a Phillips #00 screwdriver.
  5. Sony Ericsson s710a Keypad Replacement: 步骤 5 中的图像 1,1
    • Remove the plastic cover with the iFixit opening tool.
    • It is easiest to begin at the SD card slot and alternate prying the cover on opposite sides.
    • The cover will not come off completely, because there are additional screws that need to be removed, but will pry loose up to the camera.
  6. Sony Ericsson s710a Keypad Replacement: 步骤 6 中的图像 1,1
    • Using the iFixit opening tool, pry off the plastic piece at the bottom of the keypad.
    • This piece is fixed with an adhesive, so you must break the bond to reach the screws underneath. It may be necessary to use additional adhesive during reassembly.
  7. Sony Ericsson s710a Keypad Replacement: 步骤 7 中的图像 1,1
    • Remove two 6 mm screws from beneath the previously removed plastic cover using a Phillips #00 screwdriver.
    • Completely remove the back plastic cover.
  8. Sony Ericsson s710a Keypad Replacement: 步骤 8 中的图像 1,2 Sony Ericsson s710a Keypad Replacement: 步骤 8 中的图像 2,2
    • Pry the board from the plastic case using the iFixit opening tool.
    • This part is tricky. The black plastic pieces at the base of the phone hold the board in.
  9. Sony Ericsson s710a Keypad Replacement: 步骤 9 中的图像 1,1
    • After removing the board, you will see the plastic keyboard beneath. This can be removed by hand and is very flexible.
    • You have successfully removed the keypad. You can clean, decorate, or replace the keyboard without worrying about damaging the phone.
结论
另外一个人完成了本指南。
Alexander
于10/29/11注册
75 声望
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,338
