跳转到主内容
Sony Ericsson Z500a Logic Board Replacement
你所需要的
  1. Sony Ericsson Z500a Logic Board Replacement, Keypad: 步骤 1 中的图像 1,3 Sony Ericsson Z500a Logic Board Replacement, Keypad: 步骤 1 中的图像 2,3 Sony Ericsson Z500a Logic Board Replacement, Keypad: 步骤 1 中的图像 3,3
    • Remove the back cover by pulling it down, and then take out the battery.
    • Using a T6 Torx screwdriver, remove the 4 screws.
    • Keep the phone open with the back cover facing you.
  2. Sony Ericsson Z500a Logic Board Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool and run it between the case and the body of the device to loosen the keyboard
    • There are 2 clamps that lock the keyboard to the case (1 on each side)
  3. Sony Ericsson Z500a Logic Board Replacement: 步骤 3 中的图像 1,1
    • Flip the phone over and lift straight up on the key pad to remove it.
    • Be sure to hold the phone flat (parallel to the table) so that no loose parts fall out.
  4. Sony Ericsson Z500a Logic Board Replacement, Logic Board: 步骤 4 中的图像 1,2 Sony Ericsson Z500a Logic Board Replacement, Logic Board: 步骤 4 中的图像 2,2
    • Use the opening tool to remove the 2 ribbon wires (boxed in the photo) from the logic board.
    • Gently lift the back of the logic board and then pull outwards. Be careful not to rip the ribbon wire.
  5. Sony Ericsson Z500a Logic Board Replacement: 步骤 5 中的图像 1,2 Sony Ericsson Z500a Logic Board Replacement: 步骤 5 中的图像 2,2
    • Remove the black sim card reader and green vibrator before continuing to ensure they do not fall out.
结论
Tim
于04/20/10注册
15 声望
创作了2篇指南
团队
Cal Poly, Team 7-12, Maness Spring 2010 Cal Poly, Team 7-12, Maness Spring 2010 的会员
CPSU-MANESS-S10S7G12
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 1,652
