当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the back cover by pulling it down, and then take out the battery.
Using a T6 Torx screwdriver, remove the 4 screws.
Keep the phone open with the back cover facing you.
Use the plastic opening tool and run it between the case and the body of the device to loosen the keyboard
There are 2 clamps that lock the keyboard to the case (1 on each side)
Flip the phone over and lift straight up on the key pad to remove it.
Be sure to hold the phone flat (parallel to the table) so that no loose parts fall out.
取消:我没有完成这个指南。
与12其他贡献者
于04/16/10注册
1 声望
撰写一个指南
徽章: 4
+1个徽章
CPSU-MANESS-S10S7G12
4 名成员
创作了10篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 4
过去 7 天: 5
过去 30 天: 6
总计 2,725
