跳转到主内容
简介
This guide shows how to remove the phone keypad.
配件
没有特定配件。
  1. Remove the back cover and the battery. Remove the back cover and the battery. Remove the back cover and the battery.
    • Remove the back cover and the battery.
  2. Remove the 4 screws using a T6 precision screwdriver.
    • Remove the 4 screws using a T6 precision screwdriver.
    • Flip open the phone, and keep the back cover facing you.
  3. Macbook 电池维修套装
    起价 $69.99
    Buy Now
    Macbook 电池维修套装
    起价 $69.99
    Buy Now
  4. Take the plastic opening tool and run it between the phone case and phone body to loosen the key pad while the phone is open. There are 2 clamps that lock it to the phone case (1 on each side).
    • Take the plastic opening tool and run it between the phone case and phone body to loosen the key pad while the phone is open.
    • There are 2 clamps that lock it to the phone case (1 on each side).
  5. Flip the phone over and lift straight up on the key pad to remove it.
    • Flip the phone over and lift straight up on the key pad to remove it.
    • Be sure to hold the phone flat (parallel to the table), because there are loose parts that may fall out.
结论
Jory Benitez
于2010年04月16日注册
1 信誉积分
撰写一个指南
团队
Cal Poly, Team 7-12, Maness Spring 2010 Cal Poly, Team 7-12, Maness Spring 2010 的会员
CPSU-MANESS-S10S7G12
4 名成员
创作了10篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 2,602
