跳转到主内容
Sony Ericsson Xperia X10 Screen Replacement
你所需要的
  1. Sony Ericsson Xperia X10 Screen Replacement, Glass Screen: 步骤 1 中的图像 1,1
    • Remove the back cover and the battery.
  2. Sony Ericsson Xperia X10 Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the eight 5mm T6 screws from the back of the phone.
  3. Sony Ericsson Xperia X10 Screen Replacement: 步骤 3 中的图像 1,1
    • Use a case opening tool to release clips holding the case together.
    • It's easier to start at the bottom right side of the phone. Insert the tool and run it down the side of the phone, using a prying motion to pull it apart.
  4. Sony Ericsson Xperia X10 Screen Replacement: 步骤 4 中的图像 1,1
    • Take the part on the left side and put it out of the way.
  5. Sony Ericsson Xperia X10 Screen Replacement: 步骤 5 中的图像 1,1
    • Insert a flat head screw driver under the two clips and pry up.
    • The chip should come loose with just a ribbon cable holding it to the rest of the phone.
  6. Sony Ericsson Xperia X10 Screen Replacement: 步骤 6 中的图像 1,1
    • Using a flat head screwdriver, flip the chip to the left and remove the ribbon cable.
  7. Sony Ericsson Xperia X10 Screen Replacement: 步骤 7 中的图像 1,2 Sony Ericsson Xperia X10 Screen Replacement: 步骤 7 中的图像 2,2
    • Remove the volume and camera buttons. Using your fingers or a screwdriver, pull off the black plastic piece on the very top of the phone.
  8. Sony Ericsson Xperia X10 Screen Replacement: 步骤 8 中的图像 1,1
    • Using a flat head screw driver, undo the ribbon cables connected to the phone.
  9. Sony Ericsson Xperia X10 Screen Replacement: 步骤 9 中的图像 1,1
    • Gently insert a flat head screw driver under the logic board and pry to remove it from the phone casing.
  10. Sony Ericsson Xperia X10 Screen Replacement: 步骤 10 中的图像 1,1
    • Remove the logic board and put it to the side.
  11. Sony Ericsson Xperia X10 Screen Replacement: 步骤 11 中的图像 1,2 Sony Ericsson Xperia X10 Screen Replacement: 步骤 11 中的图像 2,2
    • Using a flat head screw driver, disconnect the glue holding the left ribbon cable to the phone. Pull up the black plastic piece being pointed to in the image.
  12. Sony Ericsson Xperia X10 Screen Replacement: 步骤 12 中的图像 1,2 Sony Ericsson Xperia X10 Screen Replacement: 步骤 12 中的图像 2,2
    • Using a flat head screwdriver, pry up the board.
    • Remove the power button from the top of the phone.
结论
To reassemble your device, follow these instructions in reverse order. The pieces need to be placed exactly back into the phone as they came out or else they won't fit together correctly.
Matt
于10/29/13注册
319 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-5, Shastany Fall 2013 UMass Dartmouth, Team 1-5, Shastany Fall 2013 的会员
UMASSD-SHASTANY-F13S1G5
2 名成员
创作了3篇指南
一条评论
good evening
when I put my SD card in my xperia it not appear but when I place it in another mobile standard market
djidja - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 2,179
