跳转到主内容
Sony Ericsson Xperia X10 Audio and Camera buttons Replacement
你所需要的
  1. Sony Ericsson Xperia X10 Audio and Camera buttons Replacement, Audio and Camera buttons: 步骤 1 中的图像 1,1
    • The first step in accessing the audio and/or camera buttons is to remove the back case of the phone and then the battery
  2. Sony Ericsson Xperia X10 Audio and Camera buttons Replacement: 步骤 2 中的图像 1,1
    • Use a Torx T6 screwdriver to remove eight 5 mm screws on the back case.
  3. Sony Ericsson Xperia X10 Audio and Camera buttons Replacement: 步骤 3 中的图像 1,1
    • Using an opening case, (a guitar pick works as well), start on the bottom right side of the phone and undo the clips located at the interior sides. Repeat this step for the left side.
  4. Sony Ericsson Xperia X10 Audio and Camera buttons Replacement: 步骤 4 中的图像 1,1
    • The phone should now look like this. The Volume button is indicated by the larger yellow circle, and the camera button is indicated by the smaller and lower yellow circle.
  5. Sony Ericsson Xperia X10 Audio and Camera buttons Replacement: 步骤 5 中的图像 1,1
    • The volume button (left) and the camera button (right) lift right out of the phone as shown in the picture. From here you can clean them or replace them.
结论
3等其他人完成本指南。
Nick E
于10/29/13注册
149 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-5, Shastany Fall 2013 UMass Dartmouth, Team 1-5, Shastany Fall 2013 的会员
UMASSD-SHASTANY-F13S1G5
2 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 1,814
