跳转到主内容
Sony Ericsson Xperia X10 Audio Jack Replacement
你所需要的
  1. Sony Ericsson Xperia X10 Audio Jack Replacement, Audio Jack: 步骤 1 中的图像 1,1
    • The audio jack is located on the top side of the phone, in the center. To access the audio jack disassemble is necessary.
  2. Sony Ericsson Xperia X10 Audio Jack Replacement: 步骤 2 中的图像 1,1
    • Start by having the screen of the phone facing downwards and remove the battery. Remove eight 5mm screws located as shown with a T-6 bit.
  3. Sony Ericsson Xperia X10 Audio Jack Replacement: 步骤 3 中的图像 1,1
    • Using a case opener, start on the bottom right side of the phone and undo clips located at the interior sides. Repeat this step for the left side.
  4. Sony Ericsson Xperia X10 Audio Jack Replacement: 步骤 4 中的图像 1,1
    • Once the clips are undone the back casing should dislocate and reveal the internal components of the phone. Audio jack location is identified on the image.
  5. Sony Ericsson Xperia X10 Audio Jack Replacement: 步骤 5 中的图像 1,2 Sony Ericsson Xperia X10 Audio Jack Replacement: 步骤 5 中的图像 2,2
    • The audio jack can only be accessed if the internal casing is removed. To remove this, apply pressure on the left side of internal casing and using a flat head screw driver unlatch both clips on the right side of casing.
  6. Sony Ericsson Xperia X10 Audio Jack Replacement: 步骤 6 中的图像 1,2 Sony Ericsson Xperia X10 Audio Jack Replacement: 步骤 6 中的图像 2,2
    • Audio Jack is located and easily removed. New component can be inserted.
结论
Bryan
于11/03/13注册
410 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 439
