跳转到主内容
Sony Ericsson Xperia Pro MK16A Camera Replacement
你所需要的
  1. Sony Ericsson Xperia Pro MK16A Camera Replacement, Taking the Back Off: 步骤 1 中的图像 1,3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Taking the Back Off: 步骤 1 中的图像 2,3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Taking the Back Off: 步骤 1 中的图像 3,3
    • Use a plastic opening tool to get the back cover off your phone.
    • The plastic opener will work on any side, but be careful and pry gently.
  2. Sony Ericsson Xperia Pro MK16A Camera Replacement, Removing the Battery: 步骤 2 中的图像 1,1
    • Locate the battery in your phone.
    • Find the divot below the battery.
    • Use your thumb to lift the battery out of the phone.
  3. Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove Screws: 步骤 3 中的图像 1,3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove Screws: 步骤 3 中的图像 2,3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove Screws: 步骤 3 中的图像 3,3
    • Remove the 4 black screws with the Phillips screwdriver.
    • Remove the 4 silver screws with the Torx screwdriver.
  4. Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove Back Case: 步骤 4 中的图像 1,1
    • Insert the plastic opening tool in between the two halves of the case. Pry around the phone to detach the back case.
  5. Sony Ericsson Xperia Pro MK16A Camera Replacement, Access the Logic Board: 步骤 5 中的图像 1,3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Access the Logic Board: 步骤 5 中的图像 2,3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Access the Logic Board: 步骤 5 中的图像 3,3
    • Remove the last screw that is connecting the logic board using the Phillips screwdriver.
    • Undo the two ribbons.
  6. Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove the Logic Board: 步骤 6 中的图像 1,3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove the Logic Board: 步骤 6 中的图像 2,3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove the Logic Board: 步骤 6 中的图像 3,3
    • Undo that last connector.
  7. Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove Camera: 步骤 7 中的图像 1,2 Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove Camera: 步骤 7 中的图像 2,2
    • Lift the camera off of its connector on the logic board.
结论
2等其他人完成本指南。
团队
UMass Dartmouth, Team 6-5, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-5, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S6G5
3 名成员
创作了4篇指南
一条评论
Hi,
my Sony Ericsson Xperia Pro MK16i fell onto the stone floor and now the auto focus of the camera does not work anymore. It takes photos, but they are mostly blurred. Do you know if changing the camera part would fix this problem or is the auto focus function set in some other part than the camera itself? Thank you.
Andrea - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 949
