跳转到主内容
Sony Ericsson Xperia Play Battery Replacement
你所需要的
  1. Sony Ericsson Xperia Play Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the phone around so the screen is facing a flat surface.
  2. Sony Ericsson Xperia Play Battery Replacement: 步骤 2 中的图像 1,1
    • To remove the cover, use plastic removal tool on the seam of the case.
    • Once enough force is applied, you should hear a “click” sound which indicates that cover is loose.
  3. Sony Ericsson Xperia Play Battery Replacement: 步骤 3 中的图像 1,1
    • After the “click” noise, lift the cover with your finger.
    • Do not puncture the battery. This can result in a fire.
  4. Sony Ericsson Xperia Play Battery Replacement: 步骤 4 中的图像 1,1
    • Proceed with removing the battery by lifting the battery with a small plastic pry tool.
    • Use a plastic tool for safety. If a plastic tool is not available use your fingers.
  5. Sony Ericsson Xperia Play Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the battery from the device.
  6. Sony Ericsson Xperia Play Battery Replacement: 步骤 6 中的图像 1,1
    • Once the old battery id removed, slide the new battery, with the positive/negative indicator facing up, in so that the contacts of the battery make contact with the contacts of the phone.
  7. Sony Ericsson Xperia Play Battery Replacement: 步骤 7 中的图像 1,1
    • Lightly press the battery into the phone so that it is secure.
  8. Sony Ericsson Xperia Play Battery Replacement: 步骤 8 中的图像 1,1
    • To put the cover back on, apply force until a "click" sound is heard.
结论
Pieter Boersma
于03/25/15注册
371 声望
创作了3篇指南
团队
UMass Dartmouth, Team 7-3, Cichon Spring 2015 UMass Dartmouth, Team 7-3, Cichon Spring 2015 的会员
UMASSD-CICHON-S15S7G3
3 名成员
创作了3篇指南
一条评论
Has ifixit thought about trying to make a replacement battery that would work with this? It would be good to be able to get the battery from here as well, even if it is potentially a niche market for these old phones.
waytodawn0 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 25
总计 1,553
