跳转到主内容
Sony Ericsson W810I Motherboard Replacement
你所需要的
  1. Sony Ericsson W810I Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Place your Sony Ericsson W810I screen side down with the battery cover facing up as shown.
  2. Sony Ericsson W810I Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the battery cover by applying downward pressure on the Singular Symbol and then shifting the pressure towards the bottom edge of the phone.
  3. Sony Ericsson W810I Motherboard Replacement: 步骤 3 中的图像 1,2 Sony Ericsson W810I Motherboard Replacement: 步骤 3 中的图像 2,2
    • Lift the bottom of the battery away from the phone with your thumb and rotate until the opening in the bottom of the case is oriented downward. The battery should slide out.
  4. Sony Ericsson W810I Motherboard Replacement, Case: 步骤 4 中的图像 1,3 Sony Ericsson W810I Motherboard Replacement, Case: 步骤 4 中的图像 2,3 Sony Ericsson W810I Motherboard Replacement, Case: 步骤 4 中的图像 3,3
    • Remove the two 3.9mm screws with a Phillips size #00 screwdriver.
    • Remove the two 6.35mm screws with a Torx T6 screwdriver.
  5. Sony Ericsson W810I Motherboard Replacement: 步骤 5 中的图像 1,3 Sony Ericsson W810I Motherboard Replacement: 步骤 5 中的图像 2,3 Sony Ericsson W810I Motherboard Replacement: 步骤 5 中的图像 3,3
    • Run a plastic opening tool along the edge of the back casing while prying it apart to remove it.
  6. Sony Ericsson W810I Motherboard Replacement: 步骤 6 中的图像 1,3 Sony Ericsson W810I Motherboard Replacement: 步骤 6 中的图像 2,3 Sony Ericsson W810I Motherboard Replacement: 步骤 6 中的图像 3,3
    • Turn the phone over and open the memory stick compartment.
    • Stick a plastic opening tools into the opening and twist it to gain some leverage. This should begin separating the front casing from the interior plastic support frame.
  7. Sony Ericsson W810I Motherboard Replacement: 步骤 7 中的图像 1,3 Sony Ericsson W810I Motherboard Replacement: 步骤 7 中的图像 2,3 Sony Ericsson W810I Motherboard Replacement: 步骤 7 中的图像 3,3
    • Run the plastic opening tool upwards along that side, removing the housing.
  8. Sony Ericsson W810I Motherboard Replacement, Key Pad: 步骤 8 中的图像 1,3 Sony Ericsson W810I Motherboard Replacement, Key Pad: 步骤 8 中的图像 2,3 Sony Ericsson W810I Motherboard Replacement, Key Pad: 步骤 8 中的图像 3,3
    • Peel the rubber keys away from their backing. Do not slide them off.
    • Set them aside.
  9. Sony Ericsson W810I Motherboard Replacement: 步骤 9 中的图像 1,3 Sony Ericsson W810I Motherboard Replacement: 步骤 9 中的图像 2,3 Sony Ericsson W810I Motherboard Replacement: 步骤 9 中的图像 3,3
    • Insert a plastic opening tool under the left side of the keypad backing and start to lift.
    • Lift slowly, as you can damage the ribbon cable underneath if you pull the keypad backing away too forcefully.
  10. Sony Ericsson W810I Motherboard Replacement: 步骤 10 中的图像 1,3 Sony Ericsson W810I Motherboard Replacement: 步骤 10 中的图像 2,3 Sony Ericsson W810I Motherboard Replacement: 步骤 10 中的图像 3,3
    • Insert the plastic opening tool under the ribbon cable attachment and give a small push upwards to dislodge it.
  11. Sony Ericsson W810I Motherboard Replacement, LCD Screen: 步骤 11 中的图像 1,3 Sony Ericsson W810I Motherboard Replacement, LCD Screen: 步骤 11 中的图像 2,3 Sony Ericsson W810I Motherboard Replacement, LCD Screen: 步骤 11 中的图像 3,3
    • Remove the indicated 6.35mm screws with a Torx T6 screwdriver.
  12. Sony Ericsson W810I Motherboard Replacement: 步骤 12 中的图像 1,3 Sony Ericsson W810I Motherboard Replacement: 步骤 12 中的图像 2,3 Sony Ericsson W810I Motherboard Replacement: 步骤 12 中的图像 3,3
    • Pull LCD screen gently out and the to side. Do not attempt to pull it completely away from the board below it.
    • Push up on the underside of the cable at the point of attachment with a plastic opening tool to detach it. The screen can now be separated.
  13. Sony Ericsson W810I Motherboard Replacement, Motherboard: 步骤 13 中的图像 1,3 Sony Ericsson W810I Motherboard Replacement, Motherboard: 步骤 13 中的图像 2,3 Sony Ericsson W810I Motherboard Replacement, Motherboard: 步骤 13 中的图像 3,3
    • Using a plastic opening device, push against the underside of the brown portion of the the ribbon cable to unplug it.
  14. Sony Ericsson W810I Motherboard Replacement: 步骤 14 中的图像 1,1
    • Using a plastic opening device, separate the top of the motherboard from the rest of the plastic casing.
  15. Sony Ericsson W810I Motherboard Replacement: 步骤 15 中的图像 1,3 Sony Ericsson W810I Motherboard Replacement: 步骤 15 中的图像 2,3 Sony Ericsson W810I Motherboard Replacement: 步骤 15 中的图像 3,3
    • Pull forwards slightly on the motherboard so that it starts to fall out of the casing.
    • Thread the ribbon cable through the hole in the motherboard so that it does not become caught.
结论
2等其他人完成本指南。
Lucy Bowen
于09/01/11注册
449 声望
创作了7篇指南
团队
Cuesta, Team 1-7, Zipperian Fall 2011 Cuesta, Team 1-7, Zipperian Fall 2011 的会员
CUESTA-ZIPPERIAN-F11S1G7
1 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 3,868
