跳转到主内容
Sony Ericsson W810I Camera Lens Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Sony Ericsson W810I Camera Lens Replacement, Camera Lens: 步骤 1 中的图像 1,1
    • Ensure the phone is switched off. Then press down firmly against the Cingular icon with your thumb.
    • Slide the panel down and remove the latch
  2. Sony Ericsson W810I Camera Lens Replacement: 步骤 2 中的图像 1,2 Sony Ericsson W810I Camera Lens Replacement: 步骤 2 中的图像 2,2
    • Lift the battery with your fingers and pull it out of the casing.
    • Remove the SIM card as well if you have one
  3. Sony Ericsson W810I Camera Lens Replacement: 步骤 3 中的图像 1,1
    • Remove the two outer screws using a T7 Torx screwdriver.
  4. Sony Ericsson W810I Camera Lens Replacement: 步骤 4 中的图像 1,1
    • Remove the two smaller inner screws with the Mini-Phillips screwdriver.
  5. Sony Ericsson W810I Camera Lens Replacement: 步骤 5 中的图像 1,2 Sony Ericsson W810I Camera Lens Replacement: 步骤 5 中的图像 2,2
    • Remove the back faceplate on the camera side with the blue hand wedge.
  6. Sony Ericsson W810I Camera Lens Replacement: 步骤 6 中的图像 1,3 Sony Ericsson W810I Camera Lens Replacement: 步骤 6 中的图像 2,3 Sony Ericsson W810I Camera Lens Replacement: 步骤 6 中的图像 3,3
    • Flip the phone over and pry off the front faceplate using multiple blue hand-wedges.
    • Separate the keypad from the logic board by turning it upside down and allowing it to fall into your hand.
  7. Sony Ericsson W810I Camera Lens Replacement: 步骤 7 中的图像 1,1
    • Remove the two remaining screws at the top corners of the phone.
  8. Sony Ericsson W810I Camera Lens Replacement: 步骤 8 中的图像 1,1
    • Remove the logic board with multiple blue hand-wedges. Prise the logic board away carefully to avoid damaging it or snapping the wiring.
  9. Sony Ericsson W810I Camera Lens Replacement: 步骤 9 中的图像 1,1
    • From the inside of the panel, press down on the camera lens to pop it out of its mounting.
    • Replace the lens and reverse the process to reassemble the device.
结论
Ben Micucci
于10/14/11注册
186 声望
创作了5篇指南
团队
James Madison, Team 2-2, Allen Fall 2011 James Madison, Team 2-2, Allen Fall 2011 的会员
JMU-ALLEN-F11S2G2
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,402
