跳转到主内容
配件
没有特定配件。
  1. Insert the plastic opening tool in the notch to remove the cover. Insert the plastic opening tool in the notch to remove the cover.
    • Insert the plastic opening tool in the notch to remove the cover.
  2. Use your fingers to pull up and remove the battery. Use your fingers to pull up and remove the battery.
    • Use your fingers to pull up and remove the battery.
  3. Using you finger to pull out the SIM card. Using you finger to pull out the SIM card.
    • Using you finger to pull out the SIM card.
结论
另外一个人完成了本指南。
Branden
于2012年06月27日注册
51 信誉积分
撰写一个指南
团队
Cal Poly, Team 1-5, Regan SU 2012 Cal Poly, Team 1-5, Regan SU 2012 的会员
CPSU-REGAN-SU12S1G5
3 名成员
创作了10篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 6
总计 2,062
