当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Find the small notch on the side of the phone. The notch is located by the "fast-forward" button and the "lock" switch.
Insert your plastic opening tool into the notch.
Pry off the faceplate by gently sliding the plastic opening tool around the phone while still keeping the tool under the edge of the phone.
When enough of the faceplate has been lifted it can be easily removed.
In order to replace the faceplate, simply press and snap the faceplate back onto the front of the phone.
Remove the four 2mm Phillips screws from the back housing of the phone.
Insert the plastic opening tool in the notch at the top corner of the phone.
Lift the corner and run the plastic opening tool around the phone until the back housing can easily be removed.
Remove the lends by pushing the lens from the inside of the housing.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与4其他贡献者
于06/27/12注册
121 声望
创作了2篇指南
徽章: 6
+ 3更多徽章
CPSU-REGAN-SU12S1G5
3 名成员
创作了10篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 14
总计 1,137
