跳转到主内容
Sony Ericsson W518a Camera Lens Replacement
你所需要的
  1. Sony Ericsson W518a Camera Lens Replacement, Faceplate: 步骤 1 中的图像 1,1
    • Find the small notch on the side of the phone. The notch is located by the "fast-forward" button and the "lock" switch.
  2. Sony Ericsson W518a Camera Lens Replacement: 步骤 2 中的图像 1,3 Sony Ericsson W518a Camera Lens Replacement: 步骤 2 中的图像 2,3 Sony Ericsson W518a Camera Lens Replacement: 步骤 2 中的图像 3,3
    • Insert your plastic opening tool into the notch.
    • Pry off the faceplate by gently sliding the plastic opening tool around the phone while still keeping the tool under the edge of the phone.
    • When enough of the faceplate has been lifted it can be easily removed.
    • In order to replace the faceplate, simply press and snap the faceplate back onto the front of the phone.
  3. Sony Ericsson W518a Camera Lens Replacement, Camera Lens: 步骤 3 中的图像 1,1
    • Remove the four 2mm Phillips screws from the back housing of the phone.
  4. Sony Ericsson W518a Camera Lens Replacement: 步骤 4 中的图像 1,3 Sony Ericsson W518a Camera Lens Replacement: 步骤 4 中的图像 2,3 Sony Ericsson W518a Camera Lens Replacement: 步骤 4 中的图像 3,3
    • Insert the plastic opening tool in the notch at the top corner of the phone.
    • Lift the corner and run the plastic opening tool around the phone until the back housing can easily be removed.
  5. Sony Ericsson W518a Camera Lens Replacement: 步骤 5 中的图像 1,2 Sony Ericsson W518a Camera Lens Replacement: 步骤 5 中的图像 2,2
    • Remove the lends by pushing the lens from the inside of the housing.
结论
另外一个人完成了本指南。
kgkramer
于06/27/12注册
121 声望
创作了2篇指南
团队
Cal Poly, Team 1-5, Regan SU 2012 Cal Poly, Team 1-5, Regan SU 2012 的会员
CPSU-REGAN-SU12S1G5
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 1,152
