跳转到主内容
配件
没有特定配件。
  1. Lie phone screen down on a flat smooth surface so that the camera, logos, and speaker face up. Using the provided notch on the bottom of the back cover, insert a plastic opening tool and lift upwards to remove the back cover of the phone.
    • Lie phone screen down on a flat smooth surface so that the camera, logos, and speaker face up.
    • Using the provided notch on the bottom of the back cover, insert a plastic opening tool and lift upwards to remove the back cover of the phone.
  2. Lie the cover beside the phone upon removal.  Your assembly should appear as shown this far. Insert the plastic opening tool into the crevice between the camera and the battery of the phone.  Using a gentle prying motion, lift the end of the battery and remove. After removal, recycle the defective battery appropriately.  Take the replacement battery and lie it near the phone as shown.  Your assembly should resemble the presented picture.  Note that the cover is not included in this particular photo.
    • Lie the cover beside the phone upon removal. Your assembly should appear as shown this far.
    • Insert the plastic opening tool into the crevice between the camera and the battery of the phone. Using a gentle prying motion, lift the end of the battery and remove.
    • After removal, recycle the defective battery appropriately. Take the replacement battery and lie it near the phone as shown. Your assembly should resemble the presented picture. Note that the cover is not included in this particular photo.
  3. Flip the phone over and remove the Sony Ericsson sticker that is over the phone's ear speaker. Using a T5 screwdriver, loosen and remove the two screws under the Sony Ericsson sticker by turning them counterclockwise.
    • Flip the phone over and remove the Sony Ericsson sticker that is over the phone's ear speaker.
    • Using a T5 screwdriver, loosen and remove the two screws under the Sony Ericsson sticker by turning them counterclockwise.
  4. PC 笔记本电池
    An easy fix for a big power boost.
    现在开始购物
    PC 笔记本电池
    现在开始购物
  5. Using a mini phillips head screwdriver, loosen and remove these screws by turning them counterclockwise.
    • Using a mini phillips head screwdriver, loosen and remove these screws by turning them counterclockwise.
    • Be careful to remember and organize screws to their unique positions in this step as well as future steps.
  6. Insert a prybar in bottom crack between the front and back plates (see picture) and use a gentle upward pull to separate the back case from the front case.
    • Insert a prybar in bottom crack between the front and back plates (see picture) and use a gentle upward pull to separate the back case from the front case.
    • Side buttons/controls may fall from their place in between the back and front casings.
  7. Using a T5 screwdriver, loosen and remove the two screws by turning them counterclockwise.
    • Using a T5 screwdriver, loosen and remove the two screws by turning them counterclockwise.
  8. Using a prybar and a gentle outward motion, separate the front plate from the inner phone workings. After removing the back plate and the front plate, the phone should look like the remaining pictures.
    • Using a prybar and a gentle outward motion, separate the front plate from the inner phone workings.
    • After removing the back plate and the front plate, the phone should look like the remaining pictures.
  9. Using a mini phillips head screwdriver, loosen and remove the screw located on the front number pad by turning it counterclockwise. After removing this screw, the speaker will be free to move and the phone will look like this remaining picture.
    • Using a mini phillips head screwdriver, loosen and remove the screw located on the front number pad by turning it counterclockwise.
    • After removing this screw, the speaker will be free to move and the phone will look like this remaining picture.
    • To reassemble the phone, follow these steps in reverse order.
结论
另外一个人完成了本指南。
Ldellos
于2012年03月12日注册
109 信誉积分
创作了3篇指南
团队
Clemson, Team 1-4, Benson Spring 2012 Clemson, Team 1-4, Benson Spring 2012 的会员
CLEM-BENSON-S12S1G4
4 名成员
创作了14篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 901
