跳转到主内容
Sony Ericsson W350a Keypad Replacement
你所需要的
  1. Sony Ericsson W350a Keypad Replacement, Flip Cover: 步骤 1 中的图像 1,1
    • Place the plastic opening tool in the bottom corner of the phone in the crevice between the flap to remove the cover.
  2. Sony Ericsson W350a Keypad Replacement: 步骤 2 中的图像 1,1
    • Remove the cover with a slight twisting motion.
  3. Sony Ericsson W350a Keypad Replacement, Battery: 步骤 3 中的图像 1,2 Sony Ericsson W350a Keypad Replacement, Battery: 步骤 3 中的图像 2,2
    • Place the phone face down on a flat smooth surface so that the camera, logos, and speaker face up.
    • Using the provided notch on the bottom of the back cover, insert a plastic opening tool and lift upwards to remove the back cover of the phone.
  4. Sony Ericsson W350a Keypad Replacement: 步骤 4 中的图像 1,3 Sony Ericsson W350a Keypad Replacement: 步骤 4 中的图像 2,3 Sony Ericsson W350a Keypad Replacement: 步骤 4 中的图像 3,3
    • Set the cover to the side upon removal.
    • Insert the plastic opening tool into the crevice between the camera and the battery of the phone. Using a gentle prying motion, lift the end of the battery and remove.
    • After removal, recycle the defective battery appropriately.
  5. Sony Ericsson W350a Keypad Replacement, Speaker: 步骤 5 中的图像 1,2 Sony Ericsson W350a Keypad Replacement, Speaker: 步骤 5 中的图像 2,2
    • Flip the phone over and remove the Sony Ericsson sticker that is over the phone's ear speaker.
    • Using a T5 screwdriver, loosen and remove the two screws under the Sony Ericsson sticker by turning them counterclockwise.
  6. Sony Ericsson W350a Keypad Replacement: 步骤 6 中的图像 1,1
    • Using a mini Phillips screwdriver, remove two screws by turning them counterclockwise.
  7. Sony Ericsson W350a Keypad Replacement: 步骤 7 中的图像 1,1
    • Insert an opening tool in the bottom crack between the front and back plates and use a gentle upward pull to separate the back case from the front case.
    • Side buttons/controls may fall from their place in between the back and front casings.
  8. Sony Ericsson W350a Keypad Replacement: 步骤 8 中的图像 1,1
    • Using a T5 screwdriver, remove the two screws by turning them counterclockwise.
  9. Sony Ericsson W350a Keypad Replacement: 步骤 9 中的图像 1,2 Sony Ericsson W350a Keypad Replacement: 步骤 9 中的图像 2,2
    • Using an opening tool and a gentle outward motion, separate the front plate from the inner phone workings.
  10. Sony Ericsson W350a Keypad Replacement: 步骤 10 中的图像 1,2 Sony Ericsson W350a Keypad Replacement: 步骤 10 中的图像 2,2
    • Using a Phillips head screwdriver, remove the screw from the front number pad by turning it counterclockwise.
    • Remove the speaker from the phone.
  11. Sony Ericsson W350a Keypad Replacement, Keypad: 步骤 11 中的图像 1,3 Sony Ericsson W350a Keypad Replacement, Keypad: 步骤 11 中的图像 2,3 Sony Ericsson W350a Keypad Replacement, Keypad: 步骤 11 中的图像 3,3
    • Disconnect the ribbon cable from its connection until the keypad "pops" off.
    • Remove the keypad from the phone.
结论
另外一个人完成了本指南。
Ldellos
于03/12/12注册
112 声望
创作了3篇指南
团队
Clemson, Team 1-4, Benson Spring 2012 Clemson, Team 1-4, Benson Spring 2012 的会员
CLEM-BENSON-S12S1G4
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 1,263
