跳转到主内容
Sony Ericsson W200i Speaker Replacement
你所需要的
  1. Sony Ericsson W200i Speaker Replacement, Disassembling Sony Ericsson W200i Battery: 步骤 1 中的图像 1,2 Sony Ericsson W200i Speaker Replacement, Disassembling Sony Ericsson W200i Battery: 步骤 1 中的图像 2,2
    • Slide the battery cover up and off the phone.
  2. Sony Ericsson W200i Speaker Replacement: 步骤 2 中的图像 1,2 Sony Ericsson W200i Speaker Replacement: 步骤 2 中的图像 2,2
    • Pop the battery out of its slot by lifting it up.
  3. Sony Ericsson W200i Speaker Replacement, Front Case: 步骤 3 中的图像 1,3 Sony Ericsson W200i Speaker Replacement, Front Case: 步骤 3 中的图像 2,3 Sony Ericsson W200i Speaker Replacement, Front Case: 步骤 3 中的图像 3,3
    • Insert the plastic opening tool in between the front case and the back case.
    • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
  4. Sony Ericsson W200i Speaker Replacement, Core: 步骤 4 中的图像 1,2 Sony Ericsson W200i Speaker Replacement, Core: 步骤 4 中的图像 2,2
    • Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver.
    • Note that the top 2 screws are silver and the bottom 2 screws are black.
  5. Sony Ericsson W200i Speaker Replacement: 步骤 5 中的图像 1,3 Sony Ericsson W200i Speaker Replacement: 步骤 5 中的图像 2,3 Sony Ericsson W200i Speaker Replacement: 步骤 5 中的图像 3,3
    • There is a black tab in the top left corner holding the core in place.
    • Remove the core by pulling straight up to prevent breaking the tab.
  6. Sony Ericsson W200i Speaker Replacement, Back Case: 步骤 6 中的图像 1,3 Sony Ericsson W200i Speaker Replacement, Back Case: 步骤 6 中的图像 2,3 Sony Ericsson W200i Speaker Replacement, Back Case: 步骤 6 中的图像 3,3
    • Pull back on the indicated tab of the white plastic cover to unhook it from the top of the phone.
    • Using the plastic opening tool, undo the indicated clip on the bottom of the white plastic cover.
    • Remove the white plastic cover.
  7. Sony Ericsson W200i Speaker Replacement, Speaker: 步骤 7 中的图像 1,2 Sony Ericsson W200i Speaker Replacement, Speaker: 步骤 7 中的图像 2,2
    • Remove the speaker by pulling it up and out of place with the tweezers.
结论
Andy Whitmyre
于01/12/11注册
147 声望
撰写一个指南
团队
Cal Poly, Team 14-10, Forte Winter 2011 Cal Poly, Team 14-10, Forte Winter 2011 的会员
CPSU-FORTE-W11S14G10
5 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 9
总计 4,823
