跳转到主内容
加入维修社区 - 创建账户
Sony Ericsson W200i LCD Screen Replacement
你所需要的
  1. Sony Ericsson W200i LCD Screen Replacement, Disassembling Sony Ericsson W200i Battery: 步骤 1 中的图像 1,2 Sony Ericsson W200i LCD Screen Replacement, Disassembling Sony Ericsson W200i Battery: 步骤 1 中的图像 2,2
    • Slide the battery cover up and off the phone.
  2. Sony Ericsson W200i LCD Screen Replacement: 步骤 2 中的图像 1,2 Sony Ericsson W200i LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Pop the battery out of its slot by lifting it up.
  3. Sony Ericsson W200i LCD Screen Replacement, Front Case: 步骤 3 中的图像 1,3 Sony Ericsson W200i LCD Screen Replacement, Front Case: 步骤 3 中的图像 2,3 Sony Ericsson W200i LCD Screen Replacement, Front Case: 步骤 3 中的图像 3,3
    • Insert the plastic opening tool in between the front case and the back case.
    • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
  4. Sony Ericsson W200i LCD Screen Replacement, Core: 步骤 4 中的图像 1,2 Sony Ericsson W200i LCD Screen Replacement, Core: 步骤 4 中的图像 2,2
    • Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver.
    • Note that the top 2 screws are silver and the bottom 2 screws are black.
  5. Sony Ericsson W200i LCD Screen Replacement: 步骤 5 中的图像 1,3 Sony Ericsson W200i LCD Screen Replacement: 步骤 5 中的图像 2,3 Sony Ericsson W200i LCD Screen Replacement: 步骤 5 中的图像 3,3
    • There is a black tab in the top left corner holding the core in place.
    • Remove the core by pulling straight up to prevent breaking the tab.
  6. Sony Ericsson W200i LCD Screen Replacement, LCD Screen: 步骤 6 中的图像 1,3 Sony Ericsson W200i LCD Screen Replacement, LCD Screen: 步骤 6 中的图像 2,3 Sony Ericsson W200i LCD Screen Replacement, LCD Screen: 步骤 6 中的图像 3,3
    • Undo the metal clip on each side of the core using the plastic opening tool.
    • Do not bend clips past 2mm or they could break.
  7. Sony Ericsson W200i LCD Screen Replacement: 步骤 7 中的图像 1,3 Sony Ericsson W200i LCD Screen Replacement: 步骤 7 中的图像 2,3 Sony Ericsson W200i LCD Screen Replacement: 步骤 7 中的图像 3,3
    • Gently pull the white keyboard and charging port away from the motherboard and off the phone.
  8. Sony Ericsson W200i LCD Screen Replacement: 步骤 8 中的图像 1,3 Sony Ericsson W200i LCD Screen Replacement: 步骤 8 中的图像 2,3 Sony Ericsson W200i LCD Screen Replacement: 步骤 8 中的图像 3,3
    • Undo the grey clip that holds the LCD ribbon in place by loosening one side of the clip with the plastic opening tool, then gently separate the other side of the clip from the holder.
    • The copper end of the ribbon should slide out of the housing as you pull the LCD up and away from the motherboard.
    • Using too much force may bend the copper ribbon.
结论
2等其他人完成本指南。
Austin Cade
于01/11/11注册
198 声望
撰写一个指南
团队
Cal Poly, Team 14-10, Forte Winter 2011 Cal Poly, Team 14-10, Forte Winter 2011 的会员
CPSU-FORTE-W11S14G10
5 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 60
总计 8,549
