跳转到主内容
Sony Ericsson W200i Keypad Replacement
你所需要的
  1. Sony Ericsson W200i Keypad Replacement, Disassembling Sony Ericsson W200i Battery: 步骤 1 中的图像 1,2 Sony Ericsson W200i Keypad Replacement, Disassembling Sony Ericsson W200i Battery: 步骤 1 中的图像 2,2
    • Slide the battery cover up and off the phone.
  2. Sony Ericsson W200i Keypad Replacement: 步骤 2 中的图像 1,2 Sony Ericsson W200i Keypad Replacement: 步骤 2 中的图像 2,2
    • Pop the battery out of its slot by lifting it up.
  3. Sony Ericsson W200i Keypad Replacement, Front Case: 步骤 3 中的图像 1,3 Sony Ericsson W200i Keypad Replacement, Front Case: 步骤 3 中的图像 2,3 Sony Ericsson W200i Keypad Replacement, Front Case: 步骤 3 中的图像 3,3
    • Insert the plastic opening tool in between the front case and the back case.
    • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
  4. Sony Ericsson W200i Keypad Replacement, Keypad: 步骤 4 中的图像 1,2 Sony Ericsson W200i Keypad Replacement, Keypad: 步骤 4 中的图像 2,2
    • Using the plastic opening tool, press down anywhere on the keypad to separate it from the front case.
结论
6等其他人完成本指南。
团队
Cal Poly, Team 14-10, Forte Winter 2011 Cal Poly, Team 14-10, Forte Winter 2011 的会员
CPSU-FORTE-W11S14G10
5 名成员
创作了16篇指南
一条评论
Can you guys tell me where i do get parts for these legacy phones?My jostick died on this phone.Not working at all i only can use the keypad.
Janos Lazar - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 5,494
