跳转到主内容
Sony Ericsson TM506 Motherboard Replacement
你所需要的
  1. Sony Ericsson TM506 Motherboard Replacement, Battery Cover: 步骤 1 中的图像 1,3 Sony Ericsson TM506 Motherboard Replacement, Battery Cover: 步骤 1 中的图像 2,3 Sony Ericsson TM506 Motherboard Replacement, Battery Cover: 步骤 1 中的图像 3,3
    • Firmly hold the phone between your fingers with your thumb on the battery cover.
    • Push down with your thumb until the battery cover comes off.
  2. Sony Ericsson TM506 Motherboard Replacement, Back Case: 步骤 2 中的图像 1,3 Sony Ericsson TM506 Motherboard Replacement, Back Case: 步骤 2 中的图像 2,3 Sony Ericsson TM506 Motherboard Replacement, Back Case: 步骤 2 中的图像 3,3
    • Unscrew the bottom two 5.4mm screws with a Torx T6 screwdriver.
  3. Sony Ericsson TM506 Motherboard Replacement: 步骤 3 中的图像 1,2 Sony Ericsson TM506 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove the two rubber casings for the top two screws with a plastic opening tool.
  4. Sony Ericsson TM506 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Unscrew these two 5.4mm screws with a Torx T6 screwdriver.
  5. Sony Ericsson TM506 Motherboard Replacement: 步骤 5 中的图像 1,3 Sony Ericsson TM506 Motherboard Replacement: 步骤 5 中的图像 2,3 Sony Ericsson TM506 Motherboard Replacement: 步骤 5 中的图像 3,3
    • There are eight snap hooks located around the outer case. Carefully snap these to remove the outer case.
  6. Sony Ericsson TM506 Motherboard Replacement, Sound Box: 步骤 6 中的图像 1,3 Sony Ericsson TM506 Motherboard Replacement, Sound Box: 步骤 6 中的图像 2,3 Sony Ericsson TM506 Motherboard Replacement, Sound Box: 步骤 6 中的图像 3,3
    • The sound box is attached to the case by two snap hooks.
    • Lift the sound box up to remove it from the case.
  7. Sony Ericsson TM506 Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,2 Sony Ericsson TM506 Motherboard Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Locate the 80-pin connector.
    • Carefully, lift up on the connector to separate it from the board.
  8. Sony Ericsson TM506 Motherboard Replacement: 步骤 8 中的图像 1,3 Sony Ericsson TM506 Motherboard Replacement: 步骤 8 中的图像 2,3 Sony Ericsson TM506 Motherboard Replacement: 步骤 8 中的图像 3,3
    • There are two snap hooks that attach the motherboard to the case.
    • Using a plastic opening tool, carefully lift up on the motherboard to detach it.
    • The motherboard is extremely fragile. Try to be forceful yet delicate in the removal because it will not come off easily.
结论
Daniel
于06/20/12注册
83 声望
创作了7篇指南
团队
Cal Poly, Team 1-1, Regan SU 2012 Cal Poly, Team 1-1, Regan SU 2012 的会员
CPSU-REGAN-SU12S1G1
2 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,140
