跳转到主内容
Sony Ericsson QuickShare T630 Screen Replacement
你所需要的
  1. Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Phone Enclosure: 步骤 1 中的图像 1,1
    • Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
  2. Sony Ericsson QuickShare T630 Screen Replacement: 步骤 2 中的图像 1,2 Sony Ericsson QuickShare T630 Screen Replacement: 步骤 2 中的图像 2,2
    • Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
  3. Sony Ericsson QuickShare T630 Screen Replacement: 步骤 3 中的图像 1,1
    • Slide the battery upward to remove.
  4. Sony Ericsson QuickShare T630 Screen Replacement: 步骤 4 中的图像 1,2 Sony Ericsson QuickShare T630 Screen Replacement: 步骤 4 中的图像 2,2
    • Remove the rubber plug located near the camera by gently prying upward with your fingers.
    • Gently lift the camera shield after removal of the rubber plug.
  5. Sony Ericsson QuickShare T630 Screen Replacement: 步骤 5 中的图像 1,2 Sony Ericsson QuickShare T630 Screen Replacement: 步骤 5 中的图像 2,2
    • Pry the remaining panel to loosen its contact to the phone using a spudger.
    • Slide the panel upward to remove it completely.
    • These steps will require a slight appliance of force.
  6. Sony Ericsson QuickShare T630 Screen Replacement: 步骤 6 中的图像 1,1
    • Slide the aerial upward to remove it.
  7. Sony Ericsson QuickShare T630 Screen Replacement: 步骤 7 中的图像 1,2 Sony Ericsson QuickShare T630 Screen Replacement: 步骤 7 中的图像 2,2
    • Remove the four screws located at each corner of the device.
  8. Sony Ericsson QuickShare T630 Screen Replacement: 步骤 8 中的图像 1,2 Sony Ericsson QuickShare T630 Screen Replacement: 步骤 8 中的图像 2,2
    • Gently lift and remove the front panel of the phone after removing the screws.
  9. Sony Ericsson QuickShare T630 Screen Replacement: 步骤 9 中的图像 1,3 Sony Ericsson QuickShare T630 Screen Replacement: 步骤 9 中的图像 2,3 Sony Ericsson QuickShare T630 Screen Replacement: 步骤 9 中的图像 3,3
    • This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals.
    • Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
    • Gently pull the ribbon from the circuit.
    • Remove the now disconnected screen.
  10. Sony Ericsson QuickShare T630 Screen Replacement: 步骤 10 中的图像 1,3 Sony Ericsson QuickShare T630 Screen Replacement: 步骤 10 中的图像 2,3 Sony Ericsson QuickShare T630 Screen Replacement: 步骤 10 中的图像 3,3
    • Remove the keyboard by slowly pulling it away from the circuit board.
    • There are no direct connections between the keyboard and phone.
    • These are all of the parts covered in this disassembly that make up the Sony Ericsson QuickShare T630.
  11. Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Screen: 步骤 11 中的图像 1,3 Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Screen: 步骤 11 中的图像 2,3 Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Screen: 步骤 11 中的图像 3,3
    • To place a new screen, slide the green ribbon connector into the ribbon clamp that the defective screen was pulled from.
结论
另外一个人完成了本指南。
Jeremy
于10/16/13注册
166 声望
撰写一个指南
团队
University of Maine, Team 1-1, Diaz Fall 2013 University of Maine, Team 1-1, Diaz Fall 2013 的会员
UMAINE-DIAZ-F13S1G1
4 名成员
创作了6篇指南
一条评论
Worked well until the screen replacemet - ribbon cable would not go into clamp - phone plus new screen straight in the bin - a little gutted - but hey it was an old but loved phone.
roger hiley - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,320
