本指南有最近更改,您可查看未经巡查的最新版本。
你所需要的
Remove the battery cover.
Press down firmly with your thumb and slide the cover back.
Remove two Phillips #0 screws from the battery chamber.
Remove two Torx T6 screws from the battery chamber.
Use tweezers to get a grip on the joystick
Pull off
Warning: the green film surrounding the joystick is fragile. Take care not to puncture or rip it.
3等其他人完成本指南。
一条评论
That is the joystick head and it can be removed without taking anything apart. The problem is in joystick underneath it, which is soldered and need to be replaced. I know this phone is 15 years old, I just found mine and it brought back some memories :)
