跳转到主内容
修复你的物品
维修的权力
商店
  1. Remove the battery cover.
    • Remove the battery cover.
    • Press down firmly with your thumb and slide the cover back.
  2. Remove two Phillips #0 screws from the battery chamber.
    • Remove two Phillips #0 screws from the battery chamber.
    • Remove two Torx T6 screws from the battery chamber.
  3. 未插入研究
    Mac电池维修套装
    购买维修套装
    未插入研究
    Mac电池维修套装
    购买维修套装
  4. Gently pry off the back casing.
    • Gently pry off the back casing.
    • Work an opening tool around the entire seam before attempting to pull off the casing. This action will reduce the chance of cracking the casing.
  5. Remove the casing to expose the camera's components.
    • Remove the casing to expose the camera's components.
结论
Abby Evers
于2011年10月04日注册
202 信誉积分
创作了6篇指南
团队
UW Stout, Team 1-6, Zhou Fall 2011 UW Stout, Team 1-6, Zhou Fall 2011 的会员
UWSTOUT-ZHOU-F11S1G6
4 名成员
创作了12篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 3,289
