跳转到主内容
Sony Ericsson J22Oi Screen Replacement
你所需要的
  1. Sony Ericsson J22Oi Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Before disassembling the phone, make sure the phone is powered off.
  2. Sony Ericsson J22Oi Screen Replacement: 步骤 2 中的图像 1,1
    • Flip to the back of the phone and locate the black button on the top of the phone.
  3. Sony Ericsson J22Oi Screen Replacement: 步骤 3 中的图像 1,1
    • Firmly hold down the black button on the top of the phone and gently snap off the back cover.
  4. Sony Ericsson J22Oi Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the battery by wedging it out from the back.
  5. Sony Ericsson J22Oi Screen Replacement, Screen: 步骤 5 中的图像 1,1
    • Locate the five screws indicated on the phone.
  6. Sony Ericsson J22Oi Screen Replacement: 步骤 6 中的图像 1,1
    • Use a T5 Screwdriver and unscrew the five screws.
  7. Sony Ericsson J22Oi Screen Replacement: 步骤 7 中的图像 1,1
    • Once the screws are off, there should be a plastic cover on top of your screen. Gently slide the plastic cover off.
  8. Sony Ericsson J22Oi Screen Replacement: 步骤 8 中的图像 1,1
    • Now gently pull metal cover off.
  9. Sony Ericsson J22Oi Screen Replacement: 步骤 9 中的图像 1,1
    • You should now see the screen on the front side of the phone. Wedge your finger to the side of the phone. Apply some force to pop out the screen.
  10. Sony Ericsson J22Oi Screen Replacement: 步骤 10 中的图像 1,1
    • Now that screen is removed, replace the old screen with the new screen.
    • Reassemble the device by doing the steps in reverse order.
结论
另外一个人完成了本指南。
James Au
于10/06/12注册
10 声望
创作了4篇指南
团队
Cal Poly, Team 6-36, Regan Fall 2012 Cal Poly, Team 6-36, Regan Fall 2012 的会员
CPSU-REGAN-F12S6G36
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 480
