跳转到主内容
Sony Ericsson J22Oi Charging Port Replacement
你所需要的
  1. Sony Ericsson J22Oi Charging Port Replacement, Battery: 步骤 1 中的图像 1,1
    • Before disassembling the phone, make sure the phone is powered off.
  2. Sony Ericsson J22Oi Charging Port Replacement: 步骤 2 中的图像 1,1
    • Flip to the back of the phone and locate the black button on the top of the phone.
  3. Sony Ericsson J22Oi Charging Port Replacement: 步骤 3 中的图像 1,1
    • Firmly hold down the black button on the top of the phone and gently snap off the back cover.
  4. Sony Ericsson J22Oi Charging Port Replacement: 步骤 4 中的图像 1,1
    • Remove the battery by wedging it out from the back.
  5. Sony Ericsson J22Oi Charging Port Replacement, Keypad: 步骤 5 中的图像 1,1
    • Flip to the front of the phone and apply pressure to the front frame of the phone. The frame should snap off easily.
  6. Sony Ericsson J22Oi Charging Port Replacement: 步骤 6 中的图像 1,1
    • Remove the keypad by gently pulling it from the front of the phone.
  7. Sony Ericsson J22Oi Charging Port Replacement, Screen: 步骤 7 中的图像 1,1
    • Locate the five screws indicated on the phone.
  8. Sony Ericsson J22Oi Charging Port Replacement: 步骤 8 中的图像 1,1
    • Use a T5 Screwdriver and unscrew the five screws.
  9. Sony Ericsson J22Oi Charging Port Replacement: 步骤 9 中的图像 1,1
    • Once the screws are off, there should be a plastic cover on top of your screen. Gently slide the plastic cover off.
  10. Sony Ericsson J22Oi Charging Port Replacement: 步骤 10 中的图像 1,1
    • Now gently pull metal cover off.
  11. Sony Ericsson J22Oi Charging Port Replacement: 步骤 11 中的图像 1,1
    • You should now see the screen on the front side of the phone. Wedge your finger to the side of the phone. Apply some force to pop out the screen.
  12. Sony Ericsson J22Oi Charging Port Replacement: 步骤 12 中的图像 1,1
    • Now that screen is removed, replace the old screen with the new screen.
    • Reassemble the device by doing the steps in reverse order.
  13. Sony Ericsson J22Oi Charging Port Replacement, Charging Port: 步骤 13 中的图像 1,1
    • After removing the screen, you will find the charging port located at the bottom of the phone.
  14. Sony Ericsson J22Oi Charging Port Replacement: 步骤 14 中的图像 1,1
    • Gently slide off the charging port.
结论
James Au
于10/06/12注册
10 声望
创作了4篇指南
团队
Cal Poly, Team 6-36, Regan Fall 2012 Cal Poly, Team 6-36, Regan Fall 2012 的会员
CPSU-REGAN-F12S6G36
3 名成员
创作了10篇指南
一条评论
Nice information for me , I also repairing the mobile phone
Mohit - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 1,368
