跳转到主内容
Sony ECM-MS907 Volume issue troubleshooting
  1. Sony ECM-MS907 Volume issue troubleshooting, Sony ECM-MS907 Volume issue troubleshooting: 步骤 1 中的图像 1,2 Sony ECM-MS907 Volume issue troubleshooting, Sony ECM-MS907 Volume issue troubleshooting: 步骤 1 中的图像 2,2
    • Often when using the recording range of 90 degrees, a low recording occurs. This particular setting seems tailored towards a much louder object, such as a musical instrument, etc.
    • To change this setting, change switch to the 120 degree recording range.
  2. Sony ECM-MS907 Volume issue troubleshooting: 步骤 2 中的图像 1,1
    • Another problem involves the stereo jack of the microphone being inserted into the wrong output of the external device.
  3. Sony ECM-MS907 Volume issue troubleshooting: 步骤 3 中的图像 1,2 Sony ECM-MS907 Volume issue troubleshooting: 步骤 3 中的图像 2,2
    • In this particular external device, the Sony MiniDisc player, the microphone stereo jack can mistakenly be inserted into the laptop, or "white" input.
    • Always remember to insert stereo jack into the microplug, or "red" input.
  4. Sony ECM-MS907 Volume issue troubleshooting: 步骤 4 中的图像 1,1
    • Some volume issues could be related to other external devices, such as a laptop. This particular microphone was not designed to be used with a computer.
  5. Sony ECM-MS907 Volume issue troubleshooting: 步骤 5 中的图像 1,1
    • One solution is to use a device such as a USB soundcard, which can be purchased online or at most electronics stores.
    • Simply insert soundcard into a USB input in the laptop
    • Insert stereo jack of microphone into the soundcard input marked with the "microphone" symbol.
    • This may resolve laptop related problems related to low volume during recordings.
结论
Justin Lewis
于01/23/14注册
242 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 1,196
