跳转到主内容
Sony Dream Machine ICF-C180 Speaker Replacement
你所需要的
  1. Sony Dream Machine ICF-C180 Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 Sony Dream Machine ICF-C180 Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 Sony Dream Machine ICF-C180 Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Detach the top of the plastic casing. Use a Phillips head screwdriver to unscrew the three bottom screws.
  2. Sony Dream Machine ICF-C180 Speaker Replacement: 步骤 2 中的图像 1,2 Sony Dream Machine ICF-C180 Speaker Replacement: 步骤 2 中的图像 2,2
    • Wedge a plastic opening tool between the face of the clock and the body.
    • Pry open the face of the clock away from the body.
  3. Sony Dream Machine ICF-C180 Speaker Replacement: 步骤 3 中的图像 1,2 Sony Dream Machine ICF-C180 Speaker Replacement: 步骤 3 中的图像 2,2
    • To open the top casing, pull it upward.
    • Be careful not to yank on the ribbon cable when pulling on the top casing.
  4. Sony Dream Machine ICF-C180 Speaker Replacement: 步骤 4 中的图像 1,2 Sony Dream Machine ICF-C180 Speaker Replacement: 步骤 4 中的图像 2,2
    • Pull upward on the blue and white ribbon cables to remove them. This will make it easier to remove the speaker.
  5. Sony Dream Machine ICF-C180 Speaker Replacement: 步骤 5 中的图像 1,2 Sony Dream Machine ICF-C180 Speaker Replacement: 步骤 5 中的图像 2,2
    • Desolder the wires going to the speaker with a soldering iron.
  6. Sony Dream Machine ICF-C180 Speaker Replacement: 步骤 6 中的图像 1,2 Sony Dream Machine ICF-C180 Speaker Replacement: 步骤 6 中的图像 2,2
    • Use the plastic opening tool to remove the glue from the speaker.
  7. Sony Dream Machine ICF-C180 Speaker Replacement: 步骤 7 中的图像 1,2 Sony Dream Machine ICF-C180 Speaker Replacement: 步骤 7 中的图像 2,2
    • Loosen the speaker from the remaining glue with a plastic opening tool.
    • Insert the plastic opening tool into the rail that holds the speaker and push down.
  8. Sony Dream Machine ICF-C180 Speaker Replacement: 步骤 8 中的图像 1,2 Sony Dream Machine ICF-C180 Speaker Replacement: 步骤 8 中的图像 2,2
    • Pull the speaker upward to remove it.
结论
另外一个人完成了本指南。
Caleb John
于05/31/16注册
101 声望
撰写一个指南
一条评论
HEY! that's moderately adequate...
Caleb John - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 532
