你所需要的
这个步骤还没有翻译 帮忙翻译一下
The Bottom View
First we are going to remove the Lamp by removing the screw in the first image, and opening and removing the door to the lamp
Then we unscrew the two screws on the lamp. they do not completely disconnect from the lamp. So they will remain attached after unscrewing them.
Then lift up on Lamp Handle to remove Lamp from projector assmebly
这个步骤还没有翻译 帮忙翻译一下
Now you will remove all other connectors from the outer parts of the mainboard. as marked in the Red Rectangles. Gently, pull them out of their connection place.
There is one connector from the mainboard to the little blue board in the bottom righthand corner that is connected on the underside of the mainboard. Just disconnect this one from at the blue board.
You will find that the two connectors labeled in a yellow rectangle are not connected to anything leading me to believe that this mainboard may be used with other model projectors as well.
Remove the five screws marked in the red Circles from the mainboard.
In the Third image you will find the LCD Ribbon Cable on the Center of the Board. You will remove the three of the cables by gently pulling up on either side of the tiny brown connectors attching them to the board
这个步骤还没有翻译 帮忙翻译一下
have a look at some of our main components. The LCD and Prism connected to the Lens as well as some of the cooling Channels.
You can opt to remove this little board from a fan shroud but i chose to leave it attached
I removed it to show you what it looks like anyway.
这个步骤还没有翻译 帮忙翻译一下
Now we are going to look at removing the Automatic Lens door/Cap and Zoom/Focus Dials
We must remove the Zoom/Focus Dials first in order to proceed. Remove the one screw as labeled in the red circle. and gently remove the two dials out together
Next to remove the screw holding the Autolens Cap to the rest of the unit.
这个步骤还没有翻译 帮忙翻译一下
Now you can remove the Autolens cap with motor attached( on the right)
The second image is just a view of what is left on the Unit from the left hand side.
This 3rd pic has another interesting Fan channel from the left underside of the Power supply to the Lamp assembly in two different chutes.
这个步骤还没有翻译 帮忙翻译一下
The underside of the LCD / Lens Assembly to show you the Cooling ducts leading up to the LCD panels. Neat huh?
The lens is removed by unscrewing the 4 screws located on the outer corners of the lens fixture.
New line.And a look at the lens by itself and it Zoom / Focus Ring Dials
4条评论
Hi, Thanks for such a detailed teardown. Appreciated!
I have a Sony VPL-DW120 projector. Last time, when I just pressed the remote power on button, the projector made a pop or cracking sound. Afterwards no indicator light on the panel is seen and it's not powering on at all; changed power cables and input socket but in vain. Is there any fuse which needs to be replaced or my motherboard gone? Please advise.
Regards,
hey can i ask a quick question? i’ve got a broken microswitch to replace, the one that’s used when opening the shutter. it’s an AV4 4b but i can’t find these anywhere. do you know where i can get one or a good alternative??
dear sir i have an important question can you send a message on instagram to me my name viuna.company thanks
ali akbari - 回复
