跳转到主内容
Sony DVP-SR200P Processing Board Replacement
你所需要的
  1. Sony DVP-SR200P Processing Board Replacement, Top Cover: 步骤 1 中的图像 1,2 Sony DVP-SR200P Processing Board Replacement, Top Cover: 步骤 1 中的图像 2,2
    • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
    • One 3/16" screw on the right side of the DVD player.
    • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
    • Three 3/16" screws on the back of the DVD player.
  2. Sony DVP-SR200P Processing Board Replacement: 步骤 2 中的图像 1,2 Sony DVP-SR200P Processing Board Replacement: 步骤 2 中的图像 2,2
    • Slide the cover away from the front of the DVD player until it is off.
  3. Sony DVP-SR200P Processing Board Replacement, Processing Board: 步骤 3 中的图像 1,1
    • Remove the blue tape from the processing board by gently pulling upward.
  4. Sony DVP-SR200P Processing Board Replacement: 步骤 4 中的图像 1,2 Sony DVP-SR200P Processing Board Replacement: 步骤 4 中的图像 2,2
    • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
    • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
  5. Sony DVP-SR200P Processing Board Replacement: 步骤 5 中的图像 1,1
    • Handle the processing board with care. It is fragile.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
  6. Sony DVP-SR200P Processing Board Replacement: 步骤 6 中的图像 1,1
    • Orient the DVD player so that you are facing the video and audio jacks.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
    • The processing board is now free to be removed and replaced.
结论
另外一个人完成了本指南。
Brian Hua
于01/11/13注册
80 声望
创作了3篇指南
团队
Cal Poly, Team 5-17, Forte Winter 2013 Cal Poly, Team 5-17, Forte Winter 2013 的会员
CPSU-FORTE-W13S5G17
5 名成员
创作了6篇指南
2条评论
I have Sony DVD player dvp at510p. After switching it runs then automatic Power go down while running it's process ic get hotter and hotter what's the right solutions plz help me
Dhiraj Vasave - 回复
SO my DVD player run 5to 6 minutes then automatic stop all power goes to less
Dhiraj Vasave - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,766
