跳转到主内容
Sony DVP-SR200P Power Supply Circuit Board Replacement
你所需要的
  1. Sony DVP-SR200P Power Supply Circuit Board Replacement, Top Cover: 步骤 1 中的图像 1,2 Sony DVP-SR200P Power Supply Circuit Board Replacement, Top Cover: 步骤 1 中的图像 2,2
    • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
    • One 3/16" screw on the right side of the DVD player.
    • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
    • Three 3/16" screws on the back of the DVD player.
  2. Sony DVP-SR200P Power Supply Circuit Board Replacement: 步骤 2 中的图像 1,2 Sony DVP-SR200P Power Supply Circuit Board Replacement: 步骤 2 中的图像 2,2
    • Slide the cover away from the front of the DVD player until it is off.
  3. Sony DVP-SR200P Power Supply Circuit Board Replacement, Processing Board: 步骤 3 中的图像 1,1
    • Remove the blue tape from the processing board by gently pulling upward.
  4. Sony DVP-SR200P Power Supply Circuit Board Replacement: 步骤 4 中的图像 1,2 Sony DVP-SR200P Power Supply Circuit Board Replacement: 步骤 4 中的图像 2,2
    • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
    • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
  5. Sony DVP-SR200P Power Supply Circuit Board Replacement: 步骤 5 中的图像 1,1
    • Handle the processing board with care. It is fragile.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
  6. Sony DVP-SR200P Power Supply Circuit Board Replacement: 步骤 6 中的图像 1,1
    • Orient the DVD player so that you are facing the video and audio jacks.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
    • The processing board is now free to be removed and replaced.
  7. Sony DVP-SR200P Power Supply Circuit Board Replacement, Power Supply Circuit Board: 步骤 7 中的图像 1,1
    • Caution: The circuit board contains capacitors (they look like cylinders) that can shock you if they discharge. Be careful not to touch them as you work. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • Unhook the power supply connector from the power supply board by pressing down on the small latch.
  8. Sony DVP-SR200P Power Supply Circuit Board Replacement: 步骤 8 中的图像 1,1
    • Orient the DVD player so the back of the DVD player is opposite of you.
    • Unscrew the two silver 4.8 mm Phillips #1 screws that attach the power supply circuit board to the bottom of the DVD player.
结论
4等其他人完成本指南。
Brian Hua
于01/11/13注册
80 声望
创作了3篇指南
团队
Cal Poly, Team 5-17, Forte Winter 2013 Cal Poly, Team 5-17, Forte Winter 2013 的会员
CPSU-FORTE-W13S5G17
5 名成员
创作了6篇指南
2条评论
my sony home theater showing push power protector how to resolve it.
Vinod Kumar - 回复
Service center said that we need to change motherboard. plz help me out if you can
Vinod Kumar - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 8,362
