本指南有最近更改,您可查看未经巡查的最新版本。
简介
By removing the DVD reader you will be able to install a new reader.
你所需要的
Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
One 3/16" screw on the right side of the DVD player.
One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
Three 3/16" screws on the back of the DVD player.
Orient the DVD player so the front of the DVD player is opposite of you.
Remove the two #1 Phillips screws (silver, 3/16") that attach the DVD drive to the bottom of the DVD player.
Flip the DVD drive upside down, to match the orientation of the first picture.
Carefully remove the white ribbon cable from the brace holding it in place by sliding it out towards you.
Next remove the brace from the DVD drive. Carefully wiggle and pull the brace upward as the white ribbon cable slides out through the brace.
3等其他人完成本指南。
