跳转到主内容
Sony DVP-SR200P DVD Reader Replacement
你所需要的
  1. Sony DVP-SR200P DVD Reader Replacement, Top Cover: 步骤 1 中的图像 1,2 Sony DVP-SR200P DVD Reader Replacement, Top Cover: 步骤 1 中的图像 2,2
    • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
    • One 3/16" screw on the right side of the DVD player.
    • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
    • Three 3/16" screws on the back of the DVD player.
  2. Sony DVP-SR200P DVD Reader Replacement: 步骤 2 中的图像 1,2 Sony DVP-SR200P DVD Reader Replacement: 步骤 2 中的图像 2,2
    • Slide the cover away from the front of the DVD player until it is off.
  3. Sony DVP-SR200P DVD Reader Replacement, Processing Board: 步骤 3 中的图像 1,1
    • Remove the blue tape from the processing board by gently pulling upward.
  4. Sony DVP-SR200P DVD Reader Replacement: 步骤 4 中的图像 1,2 Sony DVP-SR200P DVD Reader Replacement: 步骤 4 中的图像 2,2
    • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
    • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
  5. Sony DVP-SR200P DVD Reader Replacement: 步骤 5 中的图像 1,1
    • Handle the processing board with care. It is fragile.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
  6. Sony DVP-SR200P DVD Reader Replacement: 步骤 6 中的图像 1,1
    • Orient the DVD player so that you are facing the video and audio jacks.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
    • The processing board is now free to be removed and replaced.
  7. Sony DVP-SR200P DVD Reader Replacement, DVD Drive: 步骤 7 中的图像 1,1
    • Orient the DVD player so the front of the DVD player is opposite of you.
    • Remove the two #1 Phillips screws (silver, 3/16") that attach the DVD drive to the bottom of the DVD player.
  8. Sony DVP-SR200P DVD Reader Replacement: 步骤 8 中的图像 1,1
    • Remove the DVD drive by pulling it backward and upward while ensuring that it is free of any braces.
  9. Sony DVP-SR200P DVD Reader Replacement, DVD Reader: 步骤 9 中的图像 1,3 Sony DVP-SR200P DVD Reader Replacement, DVD Reader: 步骤 9 中的图像 2,3 Sony DVP-SR200P DVD Reader Replacement, DVD Reader: 步骤 9 中的图像 3,3
    • Flip the DVD drive upside down, to match the orientation of the first picture.
    • Carefully remove the white ribbon cable from the brace holding it in place by sliding it out towards you.
    • Next remove the brace from the DVD drive. Carefully wiggle and pull the brace upward as the white ribbon cable slides out through the brace.
  10. Sony DVP-SR200P DVD Reader Replacement: 步骤 10 中的图像 1,1
    • Remove the four silver #1 Phillips 3/16''screws to free the DVD reader from the DVD drive.
  11. Sony DVP-SR200P DVD Reader Replacement: 步骤 11 中的图像 1,1
    • Remove the DVD reader from the DVD drive by pulling it upwards off of the drive.
    • The DVD reader can now be replaced.
结论
3等其他人完成本指南。
Jose Coronel
于01/11/13注册
84 声望
撰写一个指南
团队
Cal Poly, Team 5-17, Forte Winter 2013 Cal Poly, Team 5-17, Forte Winter 2013 的会员
CPSU-FORTE-W13S5G17
5 名成员
创作了6篇指南
一条评论
Which part help to play games in dvd player
WWE Final Fighters - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 4,802
