当前版本的文档还未经巡查,您可以查看最新的已查核版本。
The screen should now detach from the primary device.
The wires, indicated with a blue box, will still connect the screen.
Remove the four rubber feet and the screws beneath.
Remove the two exposed screws on the left side.
Pull back the cables until the screw is visible.
Using spudger, push the lock clips to unlock the ribbon cable.
Using tweezers, pull the connector loose.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
