跳转到主内容
加入维修社区 - 创建账户
Sony DVP-FX730 Monitor Replacement
你所需要的
  1. Sony DVP-FX730 Monitor Replacement, Cover: 步骤 1 中的图像 1,1
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Monitor Replacement: 步骤 2 中的图像 1,1
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Monitor Replacement: 步骤 3 中的图像 1,1
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Monitor Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
  5. Sony DVP-FX730 Monitor Replacement, Monitor: 步骤 5 中的图像 1,2 Sony DVP-FX730 Monitor Replacement, Monitor: 步骤 5 中的图像 2,2
    • Use your hand to remove the small back cover by gently pulling upward.
  6. Sony DVP-FX730 Monitor Replacement: 步骤 6 中的图像 1,1
    • Using a screwdriver, remove the two 12 mm pan head screws.
  7. Sony DVP-FX730 Monitor Replacement: 步骤 7 中的图像 1,1
    • The screen should now detach from the primary device.
    • The wires, indicated with a blue box, will still connect the screen.
  8. Sony DVP-FX730 Monitor Replacement: 步骤 8 中的图像 1,2 Sony DVP-FX730 Monitor Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the wires attached to the white base using tweezers to pull them up.
  9. Sony DVP-FX730 Monitor Replacement: 步骤 9 中的图像 1,2 Sony DVP-FX730 Monitor Replacement: 步骤 9 中的图像 2,2
    • Referring back to Step 8, do the same with the wires attached to the black base.
  10. Sony DVP-FX730 Monitor Replacement: 步骤 10 中的图像 1,1
    • The screen should now be completely separated from the main device.
结论
Andrew Ward
于01/20/12注册
111 声望
创作了2篇指南
团队
Cal Poly, Team 11-21, Maness Winter 2012 Cal Poly, Team 11-21, Maness Winter 2012 的会员
CPSU-MANESS-W12S11G21
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 19
总计 3,283
