跳转到主内容
Sony DVP-FX730 Laser Replacement
你所需要的
  1. Sony DVP-FX730 Laser Replacement, Cover: 步骤 1 中的图像 1,1
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Laser Replacement: 步骤 2 中的图像 1,1
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Laser Replacement: 步骤 3 中的图像 1,1
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Laser Replacement: 步骤 4 中的图像 1,1
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
  5. Sony DVP-FX730 Laser Replacement, Laser: 步骤 5 中的图像 1,2 Sony DVP-FX730 Laser Replacement, Laser: 步骤 5 中的图像 2,2
    • Remove the large connector.
    • Remove the small connector.
  6. Sony DVP-FX730 Laser Replacement: 步骤 6 中的图像 1,1
    • Remove Philips screws with the #0 Philips Screwdriver.
  7. Sony DVP-FX730 Laser Replacement: 步骤 7 中的图像 1,1
    • Lift up the black piece connected to the wires.
    • Lift gently because the ribbon cable is attached to the bottom.
  8. Sony DVP-FX730 Laser Replacement: 步骤 8 中的图像 1,2 Sony DVP-FX730 Laser Replacement: 步骤 8 中的图像 2,2
    • Unlock the lock clip
  9. Sony DVP-FX730 Laser Replacement: 步骤 9 中的图像 1,1
    • Remove the T6 screws with the T6 screwdriver.
  10. Sony DVP-FX730 Laser Replacement: 步骤 10 中的图像 1,1
    • Gently pull the rods out with tweezers.
    • Be sure the laser is out of the way so that the rods can be removed.
  11. Sony DVP-FX730 Laser Replacement: 步骤 11 中的图像 1,2 Sony DVP-FX730 Laser Replacement: 步骤 11 中的图像 2,2
    • Pull laser off of the rods.
    • Be careful when removing the rods because a fragile metal piece may break.
  12. Sony DVP-FX730 Laser Replacement: 步骤 12 中的图像 1,1
    • The laser is now removed.
结论
团队
Cal Poly, Team 11-21, Maness Winter 2012 Cal Poly, Team 11-21, Maness Winter 2012 的会员
CPSU-MANESS-W12S11G21
4 名成员
创作了5篇指南
一条评论
where do I buy the lens?
mnmmacd - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 19
总计 4,701
