简介
To access the internals of the Sony DVP-FX730, the cover must be removed. If there is a problem with one of the components on the cover, it may need to be replaced. A screwdriver should be used to remove screws and rubber feet to remove the cover successfully.
你所需要的
Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
Punch through the warranty sticker with the spudger.
Remove the screw underneath with the Phillips screwdriver.
即将完成!
结论
