跳转到主内容
Sony DVP-FX730 Cover Replacement
你所需要的
  1. Sony DVP-FX730 Cover Replacement, Cover: 步骤 1 中的图像 1,1
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Cover Replacement: 步骤 2 中的图像 1,1
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Cover Replacement: 步骤 3 中的图像 1,1
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Cover Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
结论
Rogelio Garcia
于01/20/12注册
19 声望
撰写一个指南
团队
Cal Poly, Team 11-21, Maness Winter 2012 Cal Poly, Team 11-21, Maness Winter 2012 的会员
CPSU-MANESS-W12S11G21
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 15
总计 1,466
