简介
The motherboard paramount for the proper function of the camera, basically acting like a "brain." This guide will serve as check for electronic connections, and a full removal procedure of this critical component.
你所需要的
Remove all the 4.3mm screws on the bottom using a J000 Phillips screwdriver. There should be seven screws (4 silver, 2 black).
在这个步骤中使用的工具:Tweezers$4.99
Remove all ribbon connectors from the motherboard using tweezers. Simply grab each ribbon cable and pull straight out of the connector.
There is a hidden wire on the bottom of the board that should also be removed.
In order to reassemble your device, follow these instructions in reverse order.
2等其他人完成本指南。
1指南评论
bagaimana cara agar kamera ini bisa hidup tanpa charge terus menerus (baterai nya rusak)
