简介
The motherboard paramount for the proper function of the camera, basically acting like a "brain." This guide will serve as check for electronic connections, and a full removal procedure of this critical component.
你所需要的
Remove all the 4.3mm screws on the bottom using a J000 Phillips screwdriver. There should be seven screws (4 silver, 2 black).
即将完成!
In order to reassemble your device, follow these instructions in reverse order.
结论
另外一个人完成了本指南。
