跳转到主内容
Sony DCR-DVD 108 Front and Back Lens Replacement
你所需要的
  1. Sony DCR-DVD 108 Front and Back Lens Replacement, Sony DCR-DVD 108 Case Disassembly: 步骤 1 中的图像 1,1
    • Remove all the 4.3mm screws on the bottom using a J000 Phillips screwdriver. There should be seven screws (4 silver, 2 black).
  2. Sony DCR-DVD 108 Front and Back Lens Replacement: 步骤 2 中的图像 1,1
    • Remove the 5mm #0 Phillips screws on the underside of the LCD tuck-a-way.
  3. Sony DCR-DVD 108 Front and Back Lens Replacement: 步骤 3 中的图像 1,1
    • Remove the 2mm #0 Phillips screw behind the battery.
  4. Sony DCR-DVD 108 Front and Back Lens Replacement: 步骤 4 中的图像 1,1
    • Open the dvd cover and remove the 3 4.3mm phillips screws. Including ones in the corners that may be hidden.
  5. Sony DCR-DVD 108 Front and Back Lens Replacement: 步骤 5 中的图像 1,2 Sony DCR-DVD 108 Front and Back Lens Replacement: 步骤 5 中的图像 2,2
    • Once all the screws are removed you can safely pry open the camera case using a spudger.
  6. Sony DCR-DVD 108 Front and Back Lens Replacement, Front and Back Lens: 步骤 6 中的图像 1,1
    • Take the half of camera containing both lens components and turn front portion towards you.
    • Remove the four 4.3mm Phillips #0 screws pictured.
  7. Sony DCR-DVD 108 Front and Back Lens Replacement: 步骤 7 中的图像 1,1
    • Remove front lens and inspect for "dirt," smudges. or scratches. Use discretion, if lens appears too damaged, replace part.
  8. Sony DCR-DVD 108 Front and Back Lens Replacement: 步骤 8 中的图像 1,1
    • Gently pull lens housing to expose housing channel.
  9. Sony DCR-DVD 108 Front and Back Lens Replacement: 步骤 9 中的图像 1,1
    • With the pointed end of a plastic spudger, press latch located on the side of rear lens housing.
  10. Sony DCR-DVD 108 Front and Back Lens Replacement: 步骤 10 中的图像 1,2 Sony DCR-DVD 108 Front and Back Lens Replacement: 步骤 10 中的图像 2,2
    • Once loosened gently pull and remove lens housing. The lens should now be free to inspect and replace.
结论
In order to reassemble your device, follow these instructions in reverse order.
Elijah DeWolf
于02/09/16注册
577 声望
创作了5篇指南
团队
USF Tampa, Team 7-6, Cheng Spring 2016 USF Tampa, Team 7-6, Cheng Spring 2016 的会员
USFT-CHENG-S16S7G6
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 363
