跳转到主内容
Sony Cybershot DSC-W830 Motherboard Replacement
你所需要的
  1. Sony Cybershot DSC-W830 Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Sony Cybershot DSC-W830 Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Open the battery cover by sliding it towards you.
  2. Sony Cybershot DSC-W830 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Push the purple latch with your thumb to unlock the battery.
    • Pull the battery out.
  3. Sony Cybershot DSC-W830 Motherboard Replacement, Front/Back Panels: 步骤 3 中的图像 1,3 Sony Cybershot DSC-W830 Motherboard Replacement, Front/Back Panels: 步骤 3 中的图像 2,3 Sony Cybershot DSC-W830 Motherboard Replacement, Front/Back Panels: 步骤 3 中的图像 3,3
    • Remove the eight Phillips #000 screws.
  4. Sony Cybershot DSC-W830 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the single Phillips #000 screw found next to the battery latch.
  5. Sony Cybershot DSC-W830 Motherboard Replacement: 步骤 5 中的图像 1,2 Sony Cybershot DSC-W830 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove the middle panel on the side of the device.
    • Slowly pry the camera apart at its seem.
  6. Sony Cybershot DSC-W830 Motherboard Replacement, Lens: 步骤 6 中的图像 1,3 Sony Cybershot DSC-W830 Motherboard Replacement, Lens: 步骤 6 中的图像 2,3 Sony Cybershot DSC-W830 Motherboard Replacement, Lens: 步骤 6 中的图像 3,3
    • Disconnect all ribbon cables by using the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Once disconnected, use your fingers to lift lens out of the frame.
  7. Sony Cybershot DSC-W830 Motherboard Replacement, LCD Screen: 步骤 7 中的图像 1,3 Sony Cybershot DSC-W830 Motherboard Replacement, LCD Screen: 步骤 7 中的图像 2,3 Sony Cybershot DSC-W830 Motherboard Replacement, LCD Screen: 步骤 7 中的图像 3,3
    • Lift the power button board up off of the daughterboard.
  8. Sony Cybershot DSC-W830 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove the single Phillips #000 screw.
    • Use your hands to remove the blue daughterboard.
  9. Sony Cybershot DSC-W830 Motherboard Replacement: 步骤 9 中的图像 1,2 Sony Cybershot DSC-W830 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Flip the camera around.
    • Remove the black and orange ribbon cables.
  10. Sony Cybershot DSC-W830 Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,1
    • Remove the two remaining ribbon cables.
    • Pull the motherboard from the camera.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 14
总计 513
