跳转到主内容
Sony Cyber-shot DSC-WX220 Flash Replacement
你所需要的
  1. Sony Cyber-shot DSC-WX220 Flash Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the gray switch from lock to open position.
  2. Sony Cyber-shot DSC-WX220 Flash Replacement: 步骤 2 中的图像 1,2 Sony Cyber-shot DSC-WX220 Flash Replacement: 步骤 2 中的图像 2,2
    • Pull down on the blue tab to release the battery.
  3. Sony Cyber-shot DSC-WX220 Flash Replacement, Outer Case: 步骤 3 中的图像 1,3 Sony Cyber-shot DSC-WX220 Flash Replacement, Outer Case: 步骤 3 中的图像 2,3 Sony Cyber-shot DSC-WX220 Flash Replacement, Outer Case: 步骤 3 中的图像 3,3
    • Use a PH00 screwdriver to remove the five 3.5 mm screws.
    • Use a PH00 screwdriver to remove the two 2.5 mm screws.
  4. Sony Cyber-shot DSC-WX220 Flash Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-WX220 Flash Replacement: 步骤 4 中的图像 2,2
    • Pry apart the case gently using a plastic opening tool.
  5. Sony Cyber-shot DSC-WX220 Flash Replacement, Flash Assembly: 步骤 5 中的图像 1,1
    • Pry back the panel to the right of the screen using a plastic opening tool.
  6. Sony Cyber-shot DSC-WX220 Flash Replacement: 步骤 6 中的图像 1,1
    • Working on the left side of the screen, pry the metal panel off from the motherboard housing using a plastic opening tool.
  7. Sony Cyber-shot DSC-WX220 Flash Replacement: 步骤 7 中的图像 1,1
    • Pull out the ZIF cable from the motherboard.
    • When removing the ZF cable, pull it straight out to avoid damaging the cable.
  8. Sony Cyber-shot DSC-WX220 Flash Replacement: 步骤 8 中的图像 1,1
    • Pull the capacitor out of the shell.
    • Be careful not to shock yourself on the capacitor(metal components on the top)
  9. Sony Cyber-shot DSC-WX220 Flash Replacement: 步骤 9 中的图像 1,1
    • Unpin the flash assembly.
  10. Sony Cyber-shot DSC-WX220 Flash Replacement: 步骤 10 中的图像 1,1
    • Lift flash component toward you and gently pull the ZIF cable up and away from the camera.
结论
Kate Glazer
于03/20/18注册
621 声望
创作了5篇指南
团队
IUPUI, Team S6-G3, Baechle Spring 2018 IUPUI, Team S6-G3, Baechle Spring 2018 的会员
IUPUI-BAECHLE-S18S6G3
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 599
