跳转到主内容
Sony Cyber-shot DSC-WX100 Outer Casing Replacement
你所需要的
  1. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Battery: 步骤 1 中的图像 1,1
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: 步骤 2 中的图像 1,1
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
  3. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: 步骤 3 中的图像 1,3 Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: 步骤 3 中的图像 2,3 Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: 步骤 3 中的图像 3,3
    • Remove all of the 1mm screws using a Philips #000 Screwdriver.
    • Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
  4. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-WX100 Outer Casing Replacement: 步骤 4 中的图像 2,2
    • Use the plastic opening tool to gently remove the front and back plates of the camera.
  5. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: 步骤 5 中的图像 1,2 Sony Cyber-shot DSC-WX100 Outer Casing Replacement: 步骤 5 中的图像 2,2
    • Use a plastic opening tool to gently release the two indicated tabs.
结论
2等其他人完成本指南。
Matthew
于03/18/15注册
583 声望
创作了4篇指南
团队
Michigan Tech, Team 1-9, Lauer Spring 2015 Michigan Tech, Team 1-9, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G9
2 名成员
创作了6篇指南
一条评论
Where I can buy the Outer Casing..¿??
ING CHARLY - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 866
